Anyone ever have a problem re-installing the oil pan on a 94 4 cyl?
On the transmission side, there are two studs that hold some kind of foam piece that goes between the transmission and oil pan. This is where my headache is...
The problem I'm having is, everytime I tilt the pan and wedge it in, the gasket either smears (RTV) or kinks and binds (cork).
I've tried this twice now, and I'm getting sick of seeing oil pour out when I start it up.
What am I missing? What's the trick?
Remove that hard foam piece, along with the transmission inspection plate. it's only a few bolts, and it'll save you a lot of trouble installing the pan. Also, did you disconnect your exhaust pipe that runs down under the oil pan? if you disconnected it up at the front of the engine and then at the hook slightly back from the engine compartment, the pipe comes down quite a bit, too.
__________________ Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
OK thanks
I think that will work. I didn't realize that plate could be removed...the transmission inspection plate.
I already pulled the whole front exhaust pipe, which helped, but not enough.
I think yoiu need to remove the transmission to engine brace before you can remove the inspection plate.
It would be nice if you guys can take some pics and post so we know what's needed to get the oil pan replaced....been talked about much, but people ask the same ? again and again....move to do a DIY and sticky....
I purchased about $150 in 2 Toyota Factory Manuals as well as an $18 Haynes, there is a point at which you need to look after yourself and spend a little of your own money and time to fix YOUR car. This forum is not a one stop, hand holding, free source for auto repair.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Ouch, that hurts...anyway, good for you, you have all the resources.
If somebody can give me some pointers, I will do a DIY and then I have done something for this Forum and its very supportive members, that's all. I want to give something in return.
