Run wires from engine bay to passenger compartment? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2008, 11:16 PM   #1 (permalink)
Micky Blue Eyes
View Mickyblue's Photo Gallery
3rd Generation Run wires from engine bay to passenger compartment?
I dont know how, where do i put wires through? without taking all the dash out... i found a spot where a rubber prong stopper thing is in the left side of the engine bay behind the intake manifold, but it has foam behind it, and i'm afraid of poking through it and finding out i cant put wires there... whats the easy way of running wires there?
Mickyblue is offline   Reply With Quote
Old 07-17-2008, 11:41 PM   #2 (permalink)
G-ma Car? That's Right.
View Blackhawk3D's Photo Gallery
take the driver's side fender liner out, there's a pass through up in there.
Blackhawk3D is offline   Reply With Quote
Old 07-17-2008, 11:42 PM   #3 (permalink)
View bigbluemonkey502's Photo Gallery
when i ran my pa system i ran the wires thro a rubber plug on the passanger side of the firewall, it just pushed thru and comes out where the feet of a passanger is. if no one beats me to it ill take a picture tomorrow
bigbluemonkey502 is offline   Reply With Quote
Old 07-18-2008, 12:02 AM   #4 (permalink)
Micky Blue Eyes
ok bigbluemonkey, i know what ur talking about, but it has foam there, and goes behind the dashboard, but closer to the floor, is there a spot under the dash i can take appart so i can see up in there? i'm afraid of breaking anything.
Old 07-18-2008, 12:03 AM   #5 (permalink)
Micky Blue Eyes
should i just break a hole through the foam and run line there and try and look for it?
Old 07-18-2008, 07:25 PM   #6 (permalink)
Micky Blue Eyes
3rd Generation
i tried thru the firewall, it involved taking the bottom part of the dash out, which i couldnt pull off, it didnt want to budge, the glove box didnt want to come out either, and i'm utterly frustrated because i cant get thru the technologoly advanced material called "plastic" without ruining it, someone help me before i cry!!! :sad:
Old 07-18-2008, 07:56 PM   #7 (permalink)
View toyomoho's Photo Gallery
Look on the engine side for any wire harnesses coming through, then poke something through next to it to form a start for running your wires.
Or get a hole saw and drill. Install a grommet then use sealant to finish the job.
Old 07-18-2008, 08:56 PM   #8 (permalink)
Micky Blue Eyes
could someone take a picture and give me a good idea? i'm totally lost
Old 07-18-2008, 09:44 PM   #9 (permalink)
Micky Blue Eyes
all the ones i see that you're talking about go into the fender well which go right to my doors, which isnt the firewall.
Old 07-18-2008, 10:17 PM   #10 (permalink)
Micky Blue Eyes
sigh..... u guys must be laughing
Old 07-18-2008, 11:20 PM   #11 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
There is a passage 45 degrees bottom left of the brake booster line on the 4CYL. This hole leads u to the driver side right above the accelerator. I used that hole to do my alarm and fog lights. Much easier than through the fender. Once you get the line through u can run it pass the center console in the back to the passenger side.
Hope this helps
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 07-18-2008, 11:57 PM   #12 (permalink)
Micky Blue Eyes
i hope you're right... wait is your camry left hand or right hand drive?
Old 07-19-2008, 03:30 AM   #13 (permalink)
Micky Blue Eyes
there is no hole above the throttle pedal.... the only hole i could emagine it being there, is if my car wasnt a left had drive, and it was a right hand drive, and adsactly what you said is there, but all my ECU computers are there in the way.
Old 07-19-2008, 10:44 AM   #14 (permalink)
cruisn76's Avatar
I Camry is Left hand drive. If you look in the engine bay near the brake booster there is a plug that carries the heater cable, just yank that plug (the plug has 3 grooves once you pull it) Once you pull it use any light to shine into the hole and look under the dash 10-15cm above the pedal
