170 thermostat?
I'm having the heads done (resurfaced, valve job, gaskets) on my '93 Camry V-6 (153,000 miles on it). The water pump, timing belt and thermostat were changed less than 3,000 miles ago. Since I've ran Bar's Leaks gasket sealer (I know, not really the best thing to do!) in it, I'm also putting a new radiator in it, and I thought I'd put in a new thermostat (after flushing the whole thing, of course). The factory thermostat is a 180, but I saw a listing for a 170. I'm considering trying out the 170, since the reason I'm having the heads done is because of overheating (which occured before I ever got the car). I know that the main cause of the 3VZFE motor is head movement, but I'm sure that heat also plays into the equation.
My question is, has anyone tried a cooler thermostat on this motor? If so, did it help? Thanks for any input!
