From what I've found is the 2000 Camry came with the option of factory keyless entry only system. The transponder chip was std on XLE and available on the LE. I don't believe the security system ever came factory, needed to be dealer installed. As far as the gbs sensor, if you look under your dash, you should see a 2 1/2" square black box separate from the vip 3200 module that is directly behind your fuse box door next to the steering column. There should also be a microphone spot next to the blinky light. If you don't have a GBS sensor, the alarm only activates via door locks. Any really good thief could steal your car, even if you have an aftermarket high quality one. I am probably going to be adding the rs3200 plus to mine when I get some cash. I don't want to mess with the factory keyless entry and it's super easy to install, just plug n play. If you don't have factory keyless entry, then you would have needed the regular rs3200, connects different.
Totally stock 00' 4cyl in Sage. Looking for set of nice stock 15" alloys for cheap, got any?
