Broken outside door handle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2008, 12:20 AM   #1 (permalink)
alotawatts's Avatar
View alotawatts's Photo Gallery
My drivers side outer door lift handle is broken. Will this require pulling the inside panel to fix. Did a forum search on door handles ...no finds for outer handle info. Did find comments about the inner door panel being easy to bitch-up !
04 Highlander 01 4Runner 00 Camry 90 Chev S10
alotawatts is offline   Reply With Quote
Old 07-19-2008, 12:23 AM   #2 (permalink)
Micky Blue Eyes
View Mickyblue's Photo Gallery
mine broke off, from what i remembered, i had a friend do it for me... but it involves taking the whole inside door panel off, then going through the plastic behind where the window would be, and undo a couple bolts, and the metal bars that are attached via the plastic clips (be carefull putting those back on), those bars control the door and the locks. and reverse your steps and hook everything up and it should be good to go.
Mickyblue is offline   Reply With Quote
Old 07-19-2008, 01:48 AM   #3 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $907727
iTrader Score: 59 reviews
Its not difficult to remove the door panel or the door handle.
U will need extra long extensions for ur rachet wench to reach the door handle nuts both through the access holes tho.
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
