Ok, problem fixed and here is the explanation with some pics...
It look's like toyota wants us to go to agents for this since it was quite a simple, but tuff problem...
Here is why
P.S. BEWARE, THIS IS A RHD CAR, SO ON NORMAL CARS (LHD) EVERYTHING SHOULD BE THE SAME, ONLY MIRROR SIDES (Left is right and so on....
Firs I've removed the glove box, and found the Door Lock Control unit on left (your right) side in the corner, in the blue box...
Here is the close up of the box, with the part numbers...
Here is how the unit inside the blue box looks like...
Note: One of those two big dices (some relays) was making a "bzzzzzzzz: sound....
Here is the connector for unit...
After a good hour of trying to figure out how did this unit died, I rememberd that I should also check the fuses...
In car manual you'll find the fuse box right next to the steering wheel, and I never knew that there are three more fuses under the whole mask...
You need to remove the whole cover in order to get to them...
Those fuses are:
1. 30Amp-32V Cental Locking/El.Windows
2. 40Amp-32V Rear windscreen heater
3. 40Amp-32V Ignition (not sure about this one...i think that's the one)...
And here is the close up of them...
Well, after that one replaced, everything started working 100%...
Stupid spot to place them, since it takes a little bit of time to replace the stupid fuse....
