98 3.0 Inj pulse wayy too big - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2008, 04:53 PM   #1 (permalink)
View 98blackcamry's Photo Gallery
3rd Generation 98 3.0 Inj pulse wayy too big
I had posted on camryforums, but apparently it's not working. Perhaps someone here can help. My camry is fouling plugs quickly because the injector pulse width is too large. I was able to finally get it to idle again yesterday after drying the plugs and unhooking the battery for a few mins.
I suspect the injector pulse is so high (up to 32ms) during cranking because the Engine Load Parameter shows like 55% while cranking. How is this parameter calculated on a toyota? I think if I can get to the bottom of that problem, it will run good. All other data appears to be normal. There is one sensor that says AF FT B1S2 : 99%. I unhooked the downstream o2 sensor with no change in data. Does this parameter point towards the downstream sensor? Let me know what you think.
Also, the car seems to have a couple pretty bad oil leaks (cam seal or valve covers) and it clatters on the top end when I rev it up. When I had it idling the other day the oil light was coming on.
-Rob
98blackcamry is offline   Reply With Quote
Old 07-20-2008, 05:08 PM   #2 (permalink)
The car is still hard to start, but I let it warm up earlier. The misfire monitor is showing misfires on cylinders 1,3,5 (the back ones). If I raise the RPM to about 2k, the car seems to run smoother and the monitor shows no misfires.
There is a round thing on my fuel rail also that has a tan/yellow plastic cap on it. When I popped it off a little screw fell out with an o-ring on it. I screwed it back in, but I'm not sure what that part is or if its causing my problem. The PN on the thing is 0332 23270-62010.
Thanks, let me know if you have any insights.
-Rob
Old 07-28-2008, 10:20 AM   #3 (permalink)
I fixed it! The rear camshaft was off by like 30*. Unfortunately someone didnt change the oil often enough and its all sludged up and i suspect the cam journals are screwed up in the head. Anyone know where to get a good deal on a low mileage 1mz-fe? Thanks
-Rob
Old 07-28-2008, 03:42 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
try local salvage yards first, the internet is also a good source.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
