E153 question about filling it up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2008, 02:50 PM   #1 (permalink)
View J_Phu's Photo Gallery
3rd Generation E153 question about filling it up
So I did the swap to a E153 but now I have a problem. On Jon's page it says to use 4.4 quarts of penziol. Ok so I have the penzoil and filling it through the filler plug on top, I also have the other plug on the side open too. I only got to about two quarts when fluid starts to come out of the other plug on the side, meaning thats its full I don't get it I thought fluid copacity was 4.4 quarts, oh and what would happen if I put too much fluid in
J_Phu is offline   Reply With Quote
Old 07-21-2008, 10:39 PM   #2 (permalink)
bump anyone???
Old 07-22-2008, 07:50 AM   #3 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i did both 4cyl and V6 transaxle before, and i make sure my car is parked level on ground, no jack or ramp, and i use a $4 syphon pump from walmart to pump the gear to the refill hole slowly,
when i refilled, i have my drain plug closed and tight, then refill the gear oil from the refill hole until the gear oil over flow from the refill hole, (not the other plug on the side as you desribed)
4.4 qt sound about the right capacity.
bronzemaxell is offline   Reply With Quote
Old 07-22-2008, 03:20 PM   #4 (permalink)
Ok thnx Bronze, I wasn't sure if I was doing this right or not. Its my first time working with a manual tranny. Thnx again
