Blink Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2008, 04:18 PM   #1 (permalink)
View tommytang's Photo Gallery
Question Blink Problem
Today when I turned on the left blink, I found the frequency of the light and "click" sound doubled, that is the indication light on dash board blinked more quickly and the interval between the indication sound of blink became much shorter. There was no such problem with the right blink. What's the problem and how to fix it? Thanks!
tommytang is offline   Reply With Quote
Old 07-21-2008, 04:24 PM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
One of the turn signal bulbs on left side is burned out. Turn on the left signal get out of the car and check, either the front or the rear bulb will be out. Change the bulb and you'll be good.
uibalnme is offline   Reply With Quote
Old 07-21-2008, 04:38 PM   #3 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Check your blinker fluid level.
Chris Crash is online now   Reply With Quote
Old 07-21-2008, 04:42 PM   #4 (permalink)
uibalnme's Avatar
I was not aware that the ELECTRICAL system had FLUIDS in it. LOL
Old 07-21-2008, 04:54 PM   #5 (permalink)
Old 07-21-2008, 04:54 PM   #6 (permalink)
I checked the left front bulb and rear bulb and found that the rear bulb is normal while the front bulb is rather dim. Probably the front bulb is the cause the problem. I will buy a new bulb and change it to see the result.
Old 07-21-2008, 05:38 PM   #7 (permalink)
Do not buy from
View Zviator's Photo Gallery
Notice that if u change the different bulb with voltage, the light still goes on with double frequency ^^ that's how i did to mine.
Zviator is offline   Reply With Quote
Old 07-21-2008, 05:38 PM   #8 (permalink)
Do not buy from
That might give extra safety for u on the road IMAO ^^
Old 07-21-2008, 05:41 PM   #9 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
heh... blinker fluid
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
