1999 Camry Dash Rear Light Indicator On...Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-22-2008, 07:49 AM   #1 (permalink)
View BigDog4All's Photo Gallery
There's this little rear light indicator on the left part of the dash.
It came one about a week ago.
We have checked ALL rear lamps and they are functioning properly.
Checked the rear lights.
Checked the brake lights.
Checked the license plate lights.
Checked the emergency flashing lights.
Checked the left and right turn signal lights.
Even checked the trunk lights.
What else should I check?
The owners manual says, there is a rear bulb out.
Any clues??????
Thanks....
BigDog4All is offline   Reply With Quote
Old 07-22-2008, 10:44 AM   #2 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
Try cleaning all the connectors. Sometimes rust and corrosion causes the indicator to come on.
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 07-22-2008, 02:12 PM   #3 (permalink)
Gameroom cash: $303255
Did you check the high mounted 3rd brake light? Many times people forget about that one. Also, did you check the double filament bulbs back there? Turn on your headlights and then step on the brake pedal. Have someone check back in the rear to see what happens when the lights are on and the brake pedal is depressed.
Mike
Mike Gerber is online now   Reply With Quote
Old 07-22-2008, 02:36 PM   #4 (permalink)
druski79's Avatar
View druski79's Photo Gallery
i had the same thing happen to my 99 camry all the lights work but the light was still on. all the bulbs were okay had an extra bulb for the third break light changed it and the dash light went away. Try that it might help.
druski79 is offline   Reply With Quote
Old 07-22-2008, 08:05 PM   #5 (permalink)
Mike
Duhhhhhhhhhhhhhhhhhhhh.....
I guess out of sight, out of mind. And it was out of sight cause it was a bad bulb. I needed a third eye to see that third light.
Thanks for the help....
