A good exhaust shop can fix the flex section cheap, if they all want to charge you 20 bucks for labor and 80 bucks for a flex section buy one off ebay for nothing and have them weld that on. It shouldn;t cost you more than $50 to fix the exhaust.
As for the mifsire make sure your plugs and cap and rotor are all good, if not replace them if needed and see if that helps. Also you should probably clean the egr system as it will gunk up and stick open, that will cause misfiring.
As for the brakes just look at the front, those are disc. If the back does not look like the front then solve for x
