I have a Toyota Camry CE 2000 model. The engine check light has come on. The code it gives is P0401 that translates to Insufficient EGR flow. However, my car is running just fine. There is no change in whatsoever can be observed while driving.
The engine check light came on (on day one) after I pressed the brake paddle for several times while car was parked and ignition was off.
Though, the light went off automatically (on day two), and then I drove almost 50 miles.
But on day three it came on again. All automatically. And it has been on since then.
Can you suggest how to fix the problem. I am from Ames, Iowa. Do you know a good mechanic who can fix the problem.
Waiting your earliest reply.
Thanks,
