Hey fellow Toyotaholics, here is another fix for the AIR BAG "LIGHT ON" FIX.
Thanks for the info on the air bag light reset trick..
I replaced my evaporator expansion valve which fixed my AC problem. The commpressor worked and it had freon but no cold. Quite the repair. I had to remove the dash and upper vents to get the blower housing off. Along with th repair
I removed the passenger side air bag to get room for the repair and of coarse the
first step is to
DISCONNECT THE NEG on the battery.
Aftr the install and testing the AC I saw that the Air Bag light stayed on. after reading
A LOT. I found that it needed reset.
The first couple of times I tried it ..Didnt seem to work.. But I kept at it and...
WALAH!
The light finally did the fast flash (telling me that the SRS trouble has been reset).
AT THIS POINT I KEPT THE
KEY IN THE
"ON" POSITION While I disconnected the Tc to ground.
I looked and the light was still
OFF...
STARTED THE CAR. Let it run for 5 Min.
Turned off the car let it sit a few then tried it again and NO MORE LIGHT which means I saved the reset money to the dealer and I have a safe car with air bags that work.
THANK YOU FOR THE RESET FIX
