best spark plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2008, 09:59 PM   #1 (permalink)
View 97vulcan's Photo Gallery
best spark plugs
I searched but could find no clear answer.. What are the best spark plugs for a 1992 5SFE engine?? I just seafoamed it, and would now like to change the plugs. the car has the original wires from 1992 on it too.
Thanks,
adam
97vulcan is offline   Reply With Quote
Old 07-24-2008, 10:24 PM   #2 (permalink)
View 1996camry's Photo Gallery
please refer to your car manual for what kind of spark plugs you need to buy. look back couple last pages in your manual for spark plug spec...
I would call toyota dealer to see how much they sell per spark plug. You can buy online
http://www.trademotion.com/partlocat...&siteid=214074
online is cheaper than dealer... the part you get online is OEM part... DEALER charges too high...
1996camry is offline   Reply With Quote
Old 07-24-2008, 10:41 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Denso or NGK for plugs and wires.
2007 Camry 2.4L 5M
Old 07-24-2008, 10:55 PM   #4 (permalink)
NGK what ones?? coppers?? double Platinums?? I have only had my camry for a week, so I don't know that much about it, and the plugs it needs. Denso brand?? where can I find those??
thanks,
Adam
Old 07-24-2008, 11:11 PM   #5 (permalink)
Dunno...just use platinum plugs, no need for double platinums. Should only be $2 to $3 each and not much difference in price compared to copper plugs. Just get the regular wires from Denso or NGK, those racing wires probably won't make enough of a difference for you to notice.
2007 Camry 2.4L 5M
Old 07-24-2008, 11:23 PM   #6 (permalink)
ok on platinum NGK's. Can I get them from my local auto store?? Is there a number on the plug that I should ask for?? On my SVT, I'd use autolite double platinums. I just want a good plug, that will last a long time.
Thanks,
Adam
I seafoamed the engine using about 2/3rds of the can, and didn't foul out any plugs. I can tell the car runs even better. It has 104,000 on the engine, and the wires are from 1992. I am guessing the cap and rotor are too as well as the plugs. Whens a good time to replace all that?? I think for the time being, i will just replace the plugs.
Old 07-24-2008, 11:42 PM   #7 (permalink)
engineer in training
Gameroom cash: $145055
Wow nice find! Just go to any auto parts store and get the base spark plugs offered, no need for expensive as they aren't any better and the engine won't care at all. Replace the cap and rotor like everyone mentioned, I would check the EGR system as well since they tend to gunk up and it will improve gas mileage, enjoy the car!
Old 07-24-2008, 11:49 PM   #8 (permalink)
thanks for the help! ok on the plugs....I will do just that. How hard is it to replace the cap and rotor? I have never done this, and don't want to screw something up. LOL.. It is a great car!! for being 16 years old, I have no complaints. How do you check the EGR system?? apply vacuum and see if the engine stumbles??
Adam
Mine:
1992 Camry LE 5sfe 128,000 miles
1998 Ford Contour SVT 148,000 miles(SOLD)
Wifes:
1994 Camry LE 5sfe 224,000 miles
Old 07-25-2008, 09:35 AM   #9 (permalink)
View nikita's Photo Gallery
http://www.sparkplugs.com/more_info....73227&pid=9459
http://www.sparkplugs.com/more_info....73227&pid=2437
These are your exact OE plugs. I have had bad luck in modern engines using alternate designs from what the engineers intended. These are double platinum so they will last a long time, probably at least 60,000 miles.
nikita is offline   Reply With Quote
Old 07-25-2008, 11:04 AM   #10 (permalink)
Kisuke in rain
Mazeraski's Avatar
View Mazeraski's Photo Gallery
I just bought these a little while ago, but have yet to put them in.
http://www.ngksparkplugs.com/product...m.asp?mode=nml
They were only ~$6
I would just make sure you get either NGK or Denso, whether it be platinum or iridium.
1992 Toyota Camry LE 5SFE 4 cyl. 2.2L
A.K.A. "Ron Burgundy"
198,000 mi. (as of February 9th, 2010) and counting
Mazeraski is offline   Reply With Quote
Old 07-25-2008, 01:38 PM   #11 (permalink)
View mvftw's Photo Gallery
Rule-of-Thumb is to use the factory plug (NGK). When you use fancy plugs it may or probably will have a different heat range. Some engineer spent a lot of time to figure the right factory plug... BKR6ES-11 or BKR6E-11...
mvftw is offline   Reply With Quote
Old 07-25-2008, 08:08 PM   #12 (permalink)
There really isn't a need to use double platinums on pre-97 5S-FE. Just get the regular platinums.
2007 Camry 2.4L 5M
Old 07-25-2008, 11:11 PM   #13 (permalink)
which plug is better, BKR6ES-11 or BKR6E-11??
thanks guys
Adam
Mine:
Wifes:
Old 07-26-2008, 01:37 AM   #14 (permalink)
I don't think it makes a difference between those two plugs. Just toss a coin.
For not much more, I'd get the BKR6EGP.
Don't forget the dielectric grease and anti-seize stuff.
2007 Camry 2.4L 5M
Old 07-26-2008, 01:55 PM   #15 (permalink)
Kisuke in rain
Mazeraski's Avatar
I thought the OEM plugs were Denso, since most everything on ours cars is?
