transmission problem: "slips" from drive to neutral/revs back to drive - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2008, 12:43 PM   #1 (permalink)
View coredump's Photo Gallery
Hi all. I have a 4 cylinder 1996 Camry. Here's my problem.
1.) I'm driving along and come to a stop.
2.) I hit the gas, seems like my car slips into neutral. The revs shoot up (as there is no load). Once the revs drop, car goes back into gear.
Any insight into this? Thanks.
coredump is offline   Reply With Quote
Old 07-25-2008, 12:58 PM   #2 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
check and make sure you have enough fluid.
deezeejoey is offline   Reply With Quote
Old 07-25-2008, 01:00 PM   #3 (permalink)
Planning to do once I get off work
If fluid is fine, planning to drop the fluid to see if there's any shavings, etc...
But yes, thank you very much, please keep any comments coming
Old 07-25-2008, 03:44 PM   #4 (permalink)
View Kingdom934's Photo Gallery
I thought my '85 Camry did this a few times too. It did this when it was shifting though.
What color is the fluid for the tranny? it could use a change. I know I do since its pretty brownish.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 07-25-2008, 03:48 PM   #5 (permalink)
The fluid is relatively clean. I changed it sometime last year. I'm guessing it's a year old.
However, the fluid seems to be pretty low. (I can't really tell where the fluid level is because I can't differentiate between fluid level vs. smear/scrapped fluid.) I threw in half a quart of ATF. After that half quart (and with the motor running), the fluid level seems to be sitting near cool. With the motor off, the fluid level is at the halfway point (between cool and hot).
I just bought another quart of ATF. I want to bring it up at least halfway (between cool and hot). Going to pour it in a bit.
I'm crossing my fingers and hoping it was just a low fluid issue.
Old 07-25-2008, 04:33 PM   #6 (permalink)
Hmm...
Yea it could be the fluid. I always have problems reading the dip sticks as it keeps smearing. Takes at lease a few hald dozen tries to get an avg reading.
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
Old 07-25-2008, 04:56 PM   #7 (permalink)
Yeah, I lost count how many readings I've taken. Thank you for your replies.
Will keep everyone posted. If it isn't the fluid, I'm in some deep shit, lol.
Old 07-26-2008, 01:50 AM   #8 (permalink)
Newbie
deezeejoey's Avatar
when u were describing reminded me of my old dodge shadow. I would stop at a light then when it turned green i would hit the gas, i would get going then suddenly i would have a total loss of acceleration, then it would quickly jump back.
Turned out i was just low on fluid.
6 months later i had to get a new transmission. (i'm sure thats what you wanted to hear)
