1998 XLE V6 at Watkins Glen - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2008, 04:47 PM   #1 (permalink)
View M_Power's Photo Gallery
I'm an instructor with BMW CCA for High Performance Drivers Education. Recently I didn't take my 1997 BMW M3 to the track I took my 1998 XLE V6.
In March I updated the suspension with Tokico Shocks and Eibach Springs from recommendations in this Forum. That was a very good upgrade! I changed my brakes to Axxis Ultimates and used Super Blue brake fluid. The car handled very well and I was able to hit 110mph on the back straight before the Bus Stop.
The 1st picture is up the Esses.
The 2nd picture is through the Bus Stop
The 3rd picture is through the Toe of The Boot
I always keep my hands @ 9 & 3 on the steering wheel. You can see the amount of steering input on pictures 2 & 3! The car remained fairly flat.
M_Power is offline   Reply With Quote
Old 07-25-2008, 04:56 PM   #2 (permalink)
View Kingdom934's Photo Gallery
Ooo...
Factory fogs. I hardly see them here. Only saw one Camry with them here.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 07-25-2008, 05:04 PM   #3 (permalink)
View coredump's Photo Gallery
wow...
coredump is offline   Reply With Quote
Old 07-25-2008, 05:04 PM   #4 (permalink)
rty
Gameroom cash: $298766
View rty's Photo Gallery
Camry on the track - badass.
rty is offline   Reply With Quote
Old 07-25-2008, 05:18 PM   #5 (permalink)
I've taken my '96 Camry on a canyon run (I have a heavily modded RSX, but it was down with a broken wheel stud) and i was surprised how well it handled. I had shitty tires too.
Or it could be because I'm used to running a lot faster and since my Camry is so damn slow, it was fairly easy for me.
Old 07-25-2008, 05:22 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
you should try it with the TRD RSB...makes all the differance. thanks for sharing.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 07-25-2008, 05:39 PM   #7 (permalink)
I might try that some day. My BMW ///M3 is really my track prepared car. This is my street car with All Season radials. The tires were squelling like pigs in every corner.
I was really pleased on how well the car handled, especially for an automatic. When I took it out with the novice students it was fun catching up with BMWs in the uphill Esses and passing them on the back straight!
Old 07-25-2008, 05:43 PM   #8 (permalink)
how do you like your axxis ultimates on the camry?
(i'm running axxis ultimates on my stoptech big brake kit on my rsx.)
i need to do a brake job soon on my camry. planning to do axxis ultimates and some brembo blanks.
Old 07-25-2008, 05:53 PM   #9 (permalink)
I really like the Axxis Ultimates as Street Pads. I have used them before on the Camry and also use them as Street Pads on my ///M3. The amount of dust is low and I like the initial grip and the stopping grip of these for the money. Of course there are "better" pads with more grip available for the street, but I like these for overall value and capability and long life. On the track, after they heated up I got really good grip and for the speeds I was able to achieve with my Camry, the pads did a very good job slowing down the car.
I change to real racing pads on my ///M3 and use Toyo R888 tires. I also have a Ground Control Suspension and other performance parts on my ///M3.
Old 07-25-2008, 05:57 PM   #10 (permalink)
low dust? really? i get horrific dusting with my Axxis Ultimates (on my RSX).
i'm so used to having good grip/stopping in my rsx (stoptech bbk, axxis ultimate, used to be azenis rt615 / now bfg kdw2) that i try to brake/tailgate the same in the camry and it doesn't work out so well. lol. hoping to change that with a minimal amount of money.
Old 07-25-2008, 06:05 PM   #11 (permalink)
Maybe "low dust" is a relative term? Compared to most pads I have tried on my Camry and ///M3 the Axxis Ultimates have less dust and the amount doesn't bother me. Compared to benign street pads the Axxis Ultimates have more dust. I was comparing the amount of dust to other "performance" pads.
Do you have Drilled or Slotted rotors on the RSX?
Old 07-25-2008, 06:13 PM   #12 (permalink)
oic.
slotted. i understood drilled was merely for aesthetics (well, in old days, for brake pad gasses) and would lead to cracking.
Old 07-25-2008, 06:22 PM   #13 (permalink)
Originally Posted by coredump View Post
oic.
Of course slotted rotors will have more dust than standard rotors which is what I have on both my Camry and Track ///M3.
You are correct about drilled rotors in most cases. Most of the time they are drilled after the rotor is made. If the "holes" are part of the manufactured rotor the cracking is not nearly as bad. Also the "hole" needs to be camphered.
Old 07-25-2008, 06:23 PM   #14 (permalink)
oicc.
Old 07-25-2008, 07:29 PM   #15 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $907727
iTrader Score: 59 reviews
Awesome..thanks for shareing! I agree with Bigbird about the TRD RSB..it made a world of difference on my 96.
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
