Problem with transmission or possibly clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2008, 06:06 PM   #1 (permalink)
View tmazz71's Photo Gallery
Hey I am driving a 1997 4 Cylinder Camry (Manual) and I'm having a bit of a problem when I put it into gear/ shift gears. The problem is that after the car is put into gear (any gear) and when gas is applied the RPM's shoot up but the car doesn't seem to accelerate, almost as if I'm still holding the clutch part way in. We've changed the gear oil, checked all the fluid levels and everything seems to be ok. If anyone could provide any insight into this would be greatly appreciated. Thanks in advance
tmazz71 is offline   Reply With Quote
Old 07-25-2008, 06:20 PM   #2 (permalink)
View coredump's Photo Gallery
it sounds like the clutch.
here is a way to test the clutch, that is if you can still drive your car.
1.) take your car out on a drive, let's say 30-40 mph.
2.) put your car in the highest gear.
3.) full throttle the accelerator
4.) if your rpms fly straight up and the car doesn't move, your clutch is dead.
coredump is offline   Reply With Quote
Old 07-25-2008, 07:41 PM   #3 (permalink)
Matter of fact we have done just that earler today after we checked everything so we were leaning towards the clutch being shot but the fact that the car still shifts without trouble deturred us from being positive that its the clutch. The car still responds to the gas its just very slow to accelerate almost like the the clutch is being engaged about 1/4th of the way.
Old 07-25-2008, 08:34 PM   #4 (permalink)
A toasted clutch would not affect shifting. It's like worn brake pads would still allow you to stomp on the brakes.
Old 07-25-2008, 08:46 PM   #5 (permalink)
View Ravie_g's Photo Gallery
Agree, its the clutch. and As said it wont affect shifting. ive experienced what your describing and its your clutch lol. take a smell on under your car when the slipping happens.
TIP#134: Always make a note of the current speed limit on the road you are driving on. Just in case you need to slow down.
Ravie_g is offline   Reply With Quote
Old 07-26-2008, 10:04 AM   #6 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
Burning clutch = my favorite bad thing to smell!
Chris Crash is online now   Reply With Quote
Old 07-26-2008, 12:55 PM   #7 (permalink)
Actually I've noticed that smell and just forgot to remark about it on here. So thanks for all the help guess we'll have to replace the clutch than.
Old 07-27-2008, 05:17 PM   #8 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
if you thinking DIY on clutch replacement,
here is a good link
Clutch Replacement Write-Up
and here is mine
my clutch replacement with a lot of pictures
if you tried to follow the factory service manual, or chilton manual, they would probably instruct you to remove subframe, transaxle, and FYI, i've even done a transaxle swap without touching the subframe, because 4cyl camry gen3, gen4 transaxle is very smaller, and lighter.
bronzemaxell is offline   Reply With Quote
