Earlier this month I've noticed that my engine has become nervous at idle. I checked all spark plugs which were light tan (gapped at .043), checked all my plug wires resistances (-25kohms). Checked all injectors connectors w/a noid light (all bright). I swapped fuel injectors #1 & #2 around (still persists.) Checked timing belt marks (O.k.) Removed valve cover checked camshaft gears (aligned) I performed a compression ck. Cyl 1,3, and 4 between 170-180 psi. #2 60 psi and #2wet 150psi it smoked and ran like crap after that for about 10 minutes. Maybe the rings?? The car does not smoke at all I even had a friend follow while driving, no oil consumption what so ever. I connected a vacuum guage 17 in it pulls with the need shaking but within the 17 in. as if there is valve overlapin a high performance engine. I mention all this because 3.5 months ago I replaced the head gasket,valve stem seals and lapped the valves because it sometimes smoked a little bit of oil at start up. replaced the oil pump,water pump, timing belt, and oil pan gasket. It ran great w/ no leaks and good fuel economy. I'm tempted to A, replace the engine or B,remove the head for further inspection. Which one should I go with?
