here is the links you can download
http://www.automotiveforums.com/vbul...d.php?t=497839
to check out the resistance of your spark plugs wires...
I have another question for you... When the car died at stop light, was the car run to normal temp..gauge (hot for 20 mins/2 mins) then the car died... If it died, are you experienced hard to start the car back up? Or it only died when the engine coldl?
go the link above and start download your car manual...then start check resistance of your spark plugs... I double it's your spark plug wires....
Also, when you're on the highway... the car start died suddenly... WAS the car start to shaking (like loose power) then died or the car starts experience shaking then it died suddenly?
Was your positive and negative battery cables have corrussion around both battery terminals?
If you have currussion build up, take a toothpaste brush (make sure the one that you use then throw away when you done cleaning up) clean around both terminals.... loose the negative battery cable, then use your toothpaste brush to clean... then tight negative cable back ... then do the same way as your positive terminal cable...
one you're done... Try crank again to see the the problem go away... If not post back..then we can proceed next step in troubleshooting...
