very low rpm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2008, 10:50 PM   #1 (permalink)
View xlegendx's Photo Gallery
4th Generation very low rpm
hey, my 97 4cyl camry le has a problem.... sometimes when i start the car, it revs very low at like 200-300 rpm and when i put it in drive or reverse, it trys to go but cant and stalls... is this the idle control valve or is it something else?
xlegendx is offline   Reply With Quote
Old 07-28-2008, 11:11 PM   #2 (permalink)
View toyomoho's Photo Gallery
Could be the idle valve needs cleaning.
Old 07-29-2008, 07:58 AM   #3 (permalink)
Proud Camry/Tacoma owner
View 2TCs's Photo Gallery
I would agree. I just cleaned mine thoroughly and it idles perfectly. Especially if you have had any difficulty with cold starts, this would be the solution.
2TCs is offline   Reply With Quote
Old 07-29-2008, 12:09 PM   #4 (permalink)
so do i follow this thread? How to: Cleaning Throttle Body -4 Cylinder Engines- With Pictures
Old 07-29-2008, 02:19 PM   #5 (permalink)
I would try that and hope it works, but I found that I needed to remove the IAC to get it working again. I sprayed and sprayed in many sessions over a long period of time and no luck. After I had become convinced that it was the IAC and that (in my case) spraying cleaner down the square hole wouldn't work, I decided to get serious and actually got my hands dirty and removed the throttle body and took the IAC apart (I am not recommending this - just in my case I didn't think I had a choice - and had nothing to lose).
The IAC is now working like new (I also found that I neede to disconnect the neg battery terminal after reinstalling the IAC to get it operating correctly).
I would not advise any of the above unless you feel comfortable doing it and are willing to purchase new components if things don't go according to plan.....
