After seemingly everyone else, I FINALLY put together a CAI today...
It took around an hour and half from start to finish, and removing the stock hose was the most time-consuming part of it.
On the 5S-FE, all the way to the side of the engine bay, are the two fuse boxes (as most of you know)...
And the only way to easily get the tubing out is to remove those boxes, then the stock intake tubes...
HOWEVER... on my Camry, the bolts that hold both of the fuse boxes to the engine are completely rounded-off...
... and the other one ...
So that hose wouldn't come out no matter what I used to grip the bolts!!!
And then the very same thing happened with the bottom of the stock air box itself...
The bolts weren't flat enough to wrench off, nor grip and pull...
So with both of these pieces......
I basically just ripped it off with my hand, and jimmied the stock hose through the wheel well...
As you can see, it was broken off =(
BUT anyway I ended up taking off the wheel, breaking off the second resonator, twisting and turning the stock hose through the wheel well, and setting up an amatuerish cold air intake!
Wooo....!
And.......
Leading down towards here.........
And from here it leads to...........!
Close up.....
And outside shot..............!
And that's all folks... thanks for checking it out.
What do I have to say overall about it?
It's a pretty decent mod, for the amount of money and time used.
I spent less than $100 on everything, and ended up with very minor scrapes after all the screwing up installing.
And the car feels/sounds pretty damn good after it all!
I used:
-Spectre products: 60 degree arm, 45 degree arm, High Flow Filter, Large Aluminum Tubing, Flexitubing, 5-6 couplers/braces.
-Found at autozone, kragen, any auto parts retailer (Autozone was the cheapest though).
Here's a Camera-Phone quality, sideways shot, short video of what it sounded like immediately after the install!
http://www.youtube.com/watch?v=vNKcbGsCb4E
Thanks a bunch for the inspiration, and I hope to document all my future mods too!
