A/C doesn't blow on low setting..need solution!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2008, 06:32 AM   #1 (permalink)
View ragga900's Photo Gallery
Hi,
I have a 2000 camry CE, the a/c blows cold when you turn the switch on hi or the notch before high. But when you turn the a/c to low and the notch beside it the a/c does not blow anything.., so basically you have to keep the a/c on high at all times ...Is it the a/c switch and is it easy to fix yourself.
Thanks, Any help is greatly appreciated.
ragga900 is offline   Reply With Quote
Old 07-29-2008, 07:34 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Do you mean the blower fan doesn't operate at low speed? If so it's the blower speed resistor - replace it.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 07-29-2008, 03:18 PM   #3 (permalink)
thanks, thats exactly what i'm talking about. i will change that and see if it does the trick.
Old 07-29-2008, 06:04 PM   #4 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
It's actually called the blower motor resistor..but same thing. I got one at the junk yard for $4.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 07-29-2008, 06:17 PM   #5 (permalink)
yes, you guys are exactly right. i got the part and installed it. it only took about 10 min to change. the a/c works fine. the original part was rusty. thanks for your input.
Old 11-03-2008, 08:04 AM   #6 (permalink)
View mbba's Photo Gallery
pls any pic showing how to change Blower Resistor in camry 99? need it urgent
mbba is offline   Reply With Quote
