Removing Shifter 95 Camry I4 LE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2008, 11:49 PM   #1 (permalink)
View NAthanpoulson's Photo Gallery
I cant remove my shifty.. The OD button wire is stopping me from pulling it off.. I spent a good hour trying to figure it out, but i cant. Is there a way to take the OD button out.?
NAthanpoulson is offline   Reply With Quote
Old 07-30-2008, 12:58 AM   #2 (permalink)
Nate1127's Avatar
View Nate1127's Photo Gallery
i have a 98 camry with the same problem except i cant even get shift knob off at all
Nate1127 is offline   Reply With Quote
Old 07-30-2008, 01:02 AM   #3 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Just cut the wires, and splice them back together when you're done.
uibalnme is offline   Reply With Quote
Old 07-30-2008, 01:50 AM   #4 (permalink)
I dont like doing that though, shit gets messy.. I see a plug end.. but when i try to follow it, it dissapears under the shift link and stuff.
Old 07-30-2008, 02:22 AM   #5 (permalink)
uibalnme's Avatar
It's really easy, and clean if done properly, and if you take your time. You've already said you tried for an hour to figure it out.
It took me an hour to to this to my car...
I cut the old wires, and spliced them into the wires of the new switch.
Old 07-30-2008, 02:31 AM   #6 (permalink)
nice shifter, I think about it, thank you for the info. hehe
cuz right now, im not doing this for a new shifter, im doing it for the panels under it. The PRNDL2 panel and stuff..
Old 07-30-2008, 02:40 AM   #7 (permalink)
uibalnme's Avatar
I just used a couple of butt connectors, and a crimping tool/wire stripper. Just strip the ends of the wires, and install a butt connector between the exposed wire ends with the crimping tool. Done.
You could even get away with just stripping the ends of the wires, and twisting them together, then wrapping the connection in electrical tape.
Old 12-09-2011, 12:31 AM   #8 (permalink)
Falloutkid90's Avatar
View Falloutkid90's Photo Gallery
Did you make the pipe shorter? Or is that just the height of the new shifter?
Falloutkid90 is offline   Reply With Quote
Old 12-09-2011, 01:05 AM   #9 (permalink)
uibalnme's Avatar
WOW! I haven't seen this thread in a while. Anyway, no, I didn't cut anything but the black plastic cover tube that came with the shift knob. The new shift knob is about 2 - 2.5" shorter than the stock one.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
