Squeeky disgustingly loud brakes....! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2008, 02:21 PM   #1 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation Squeeky disgustingly loud brakes....!
Okay SO.... ever since my last brake rotors/pads change my brakes have been ALRIGHT...
Except after driving with them for around 5-6 miles, they begin sounding like a small girl shrieking her head off through a megaphone.
I've used 5 different types of disc brake cleaners, all to no avail. I've replaced the brake fluid several times, all to no avail.
SO! While I was installing my CAI, I decided I would inspect the pads and rotors.
Pads looks barely used-as I expected, and the rotors looked okay.
BUT my question is, how do I know if the rotors are solid? Is there anything in particular I should be looking out for? The brake pads looked good, and I can tell how to check them, BUT the rotors I don't know as well.
Side Note: Brakes are my weakpoint with car knowledge. Though they are pretty simplistic to understand, I have yet to delve into that subject completely.
ANY HELP WOULD BE GREATLY APPRECIATED!
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 07-30-2008, 02:31 PM   #2 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
Did you check to see if there are any retaining clips that could be scraping the rotors?
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 07-30-2008, 03:02 PM   #3 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
Crap... in the front I don't think there was, but I didn't check the back.
Thanks
ACCIDENT...
Thanks
Old 07-31-2008, 09:47 AM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
Did you use aftermarket pads? In my experience with my '92, anything other than Toyota OEM brake pads squeal like crazy, regardless of what you do to try to make it go away. I tried two different brands (from NAPA and Checker Auto), and a couple of anti-squeal goops that go on pad's backing plate, between the piston and plate. Nothing would make that obnoxiously loud squeal go away. And there was no "sweet spot" of brake pedal pressure that was quiet.
I believe Toyoto's pads are non-metallic, so my conclusion was that any metallic pads will squeal. YMMV.
BMR is offline   Reply With Quote
Old 07-31-2008, 11:40 AM   #5 (permalink)
G-ma Car? That's Right.
View Blackhawk3D's Photo Gallery
I have some low priced replacement pads on my car that my friend (we take all our cars to his shop) pad slapped when he was fixing my right wheel bearing because I had to leave soon and he was too busy to do a full brake job, plus I couldn't afford it. They squealed to high heaven no matter what I did. Yesterday I took them apart and scuffed up the rotors and pads with 100 grit, followed by a wire brush on a drill on the rotors and then rescuffing the braking surface with 100 grit again. So far so good, only a tiny bit of squeak at one or two distinct pressures.
Nathan
Blackhawk3D is offline   Reply With Quote
Old 07-31-2008, 03:25 PM   #6 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
These were OEM pads, that's the confusing part! And what leads me to believe something is probably scratching against the rotors...
ACCIDENT...
Thanks
Old 07-31-2008, 03:27 PM   #7 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
Nathan
Hmm.. If I don't find anything wrong with the rotors maybe I'll give this a shot.
Is there any downside to doing this to your rotors and pads?
Thanks guys
ACCIDENT...
Thanks
Old 07-31-2008, 07:20 PM   #8 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Nope, no downside to scuffing up the surfaces. Just don't go nuts and sand too much. I think the squealing will return tho.
Give this CRC "disk brake quiet" stuff a try. I've had fairly good results with it, except of course with the metallic pads I mentioned.
Old 08-01-2008, 08:35 AM   #9 (permalink)
Redracer
redracer_13's Avatar
View redracer_13's Photo Gallery
i had the exact same problem that you have been experiencing. towards the end it became too embarrassing with the brake squeal that we got the mechanic to look at the brakes. the rotors were in perfect condition so the mechanic just replaced the brake pads (they were basically still new pads already in the car). Well once he changed the pads the problem went away. He explained to us that it could have been the compound that the pads were made from (luckily he charged us nothing for the pad replacement as he believed the old pads were faulty).
So i'd just replace the pads with a new set and hopefully the sound will disappear.
redracer_13 is offline   Reply With Quote
Old 08-01-2008, 01:40 PM   #10 (permalink)
Gameroom cash: $303255
The rotors should be OK, as long as there is no pulsation. If you don't find anything scraping the rotors then move on to checking the pads and the way they are installed. Did you use the 2 anti-squeal shims on the back of the Toyota OEM pads. If not, they need to be installed on the OEM pads. If they are already in place, then I would remove them and try the stuff BMR has suggested. Many brake noises come from the pads vibrating in the calipers. This stuff is tacky and makes the pads stick to the piston on one side of the caliper and the other pad to the caliper itself. It eliminates the vibration that could be causing the noise. Just make sure not to get any on the surface of the pads that contact the rotors.
Mike
Mike Gerber is online now   Reply With Quote
Old 08-01-2008, 02:17 PM   #11 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
x2
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 08-02-2008, 10:57 PM   #12 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
Thanks a lot guys, I'll give these ideas a try!
I'm way too broke to friggin' buy new rotors right now and replace anything really.
So... thanks
ACCIDENT...
Thanks
Old 08-04-2008, 07:26 PM   #13 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
THANK YOU!
Just wanted to say thanks a million guys, my brakes sound brand new, and smoooth now!!!!
Thanks so much
ACCIDENT...
Thanks
