94 camry possible bad ECU - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2008, 08:31 PM   #1 (permalink)
View waveslayer's Photo Gallery
Angry 94 camry possible bad ECU
Driving down the road the other day and the car died. It hasn't fired since. No fuel, no spark and all the fuses and relays are good. No power to the fuel pump, and no spark... Could this be anything but the ECU?
waveslayer is offline   Reply With Quote
Old 07-31-2008, 08:52 PM   #2 (permalink)
Gameroom cash: $845900
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Um, Alternator died? No power?
'95 Corolla AE101...
Old 07-31-2008, 10:42 PM   #3 (permalink)
Nope can't be alternator, battery has plenty of juice and the motor doesn't have to be turning over for the fuel pump to spin up after reseting it by disconnecting and reconnecting the battery. The key just has to be to the on possition to send power to the fuel pump, and their is no power at the pump or beyond the open circuit relay. When the engine is turned over their is no spark. The only thing that links these two problems is the ECU. I'm just wondering if theirs anything i'm missing..
The alternator doesn't play a roll in the fuel pump circuit at this piont i don't think... I believe its just the EFI relay, fuse and Open Circiut relay. Their also is no current being sent to the open circuit relay from the CPU..
Old 08-01-2008, 11:27 PM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
When you turn the key to the on position, does the Check Engine Light come on with the rest of the dash lights for the POST check?
The ignition switch could possibly affect both. It makes several different connections when turned, not just one.
I recall that the ECM will shut down the fuel pump if it gets a mal-function signal or no signal from somewhere. I think it is through the distributor pick-up coils but I am not certain.
Toyota ECMs are very reliable. It is usually something else, though not always...
Kep
Old 08-01-2008, 11:39 PM   #5 (permalink)
View toyomoho's Photo Gallery
Timing belt broke?
Old 08-01-2008, 11:45 PM   #6 (permalink)
_
Gameroom cash: $218135
View uuuuu's Photo Gallery
Battery posts loose or corroded? A similar thing happened to me a few months ago when the posts were loose.
uuuuu is offline   Reply With Quote
