Originally Posted by tran.man48
I know they have that krylon paint that chemically bonds to plastic/vinyl surfaces. I've never used it before though, so I can't say how well it holds up.
That's the only paint I use, I used it on plastic, fiberglass, metal and even wood. Dries super fast and it HOLDS. It's also strong, I used it on a piece of plastic that needed a little bending, no cracks or peel. I just recommend that you use a clear coat with Krylon to make the bond even stronger.
GOOD TIP: Use paint thinner to clean the parts and take your time on this step to make sure you have the strongest bond as possible
