Originally Posted by toyomoho
There are two lights for brakes, one for brake fluid/parking brake and the other for tail/brake light being out.
If you have the foot type, look under the dash in the upper area of where the brake system attaches to the frame. The movement of the arm when pushed down releases the switch.
Thanks for the reply.
Not sure I totally understand what you mean by "releases" the switch.,. If it means that the switch opens when the brake it released, then disconnecting the wire from the switch would turn the light off. However I suspect that the switch closes when the brake is released and grounds the circuit.
Do you have a schematic? Does the switch close or open when the brake is released? Is it tied to Ground when closed?
I do see a green wire up near the top of the brake, with a connector on it, not connected to anything. Couldn't feel anything to plug it into and didn't see any other wires in that area. Probably vibrated loose. I'll try to find where it plugs in and let you know if that fixes the problem. If that is the wire and the circuit works like I suspect it does, I could ground the wire to see if that fixes it until I can replace the switch.,.
Sorry it I sound like a dope, but I'm an electrical technician, wearing a mechanics hat whenever I have to. I can read the schematic and follow the logic of the circuits like it's a map of my backyard, but we use terms about switches a little different.
