2 parter - wire run and dash lights
Hey guys i got a 2 parter for you.
I have a head unit hooked up to the wiring under the passenger seat (cut the factory amp out). The wires for the front left speaker are shot somewhere between the seat and the door. So, Im going to run the wire from the head unit directly to the wiring in the door. What would be the best way of going about this?
Additionally, every now and then two lights light up on my dash. This is the battery light and the brake light is out light. They flash together whenever this happens. All my brake lights work and my battery is fine. Any idea what this could be. It happens at random times, not just when i hit my break or whatever. Sometimes theyll flash just once, sometimes theyll flash 3 or 4 times, sometimes theyll light up for about 5 seconds then go off. There is no effect in the performance of the car. Car runs 100%.
Whatever controls my cruise control is messed up because my car can cruise straight but when it needs to shift or brake it jerks and the cruise control shuts off. The transmission is fine though otherwise. The 2 dash lights flash when cruise is off though. Are these connected somehow?
Also, every now and then, the clock turns off and on but does not reset.
Any help would be appreciated. Thanks in advance!
