Shift Solenoid A problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2008, 08:38 PM   #1 (permalink)
View Grtguitarplyr420's Photo Gallery
I have a 2000 Camry LE I4 with theft system, and it keeps pulling a P0753 code whichis an open or short for Shift Solenoid A. I replaced the solenoid and the computer and it's still pulling that code. What should I do?
Grtguitarplyr420 is offline   Reply With Quote
Old 10-06-2008, 06:42 PM   #2 (permalink)
'94 Camry V6/'02 Sequoia
View ToyotaJimD.'s Photo Gallery
If you have not resolved this issue, try disconnecting the battery for a half hour and see if that resets it.
What were your original symptoms, by the way?
1994 Camry V6 XLE - Cashmere Beige
2002 Sequoia - White
ToyotaJimD. is offline   Reply With Quote
Old 10-07-2008, 06:42 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Broken solenoid wire or connector? Did you bench test the solenoid before replacing it?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 10-07-2008, 09:20 PM   #4 (permalink)
Wink
It ended up being when I put my motor back in after replacing the timing belt and water pump, i accidently ran the harness between the two throttle body hoses. It pinched the harness to the EGR valve, melted three wires together, and grounded the shift solenoid.
