High Engine RPM before shifting out of 1st
Hi guys
I really need your help as I really want to keep this car.
My problem is that my transmission will not shift out of 1st until the RPMs hit around 3k during slow acceleration, I usually have to let off the gas to force it to shift up. If I do a bit more aggressive acceleration then it wont shift until 4 or 5k. All the other gears 2nd to 3rd and 3rd to 4th shift fine. Also just recently we took the car to a transmission shop to get it repaired cause it was leaking. So they looked at it and concluded that the gaskets and valves were needed to get replaced and a transmission cooler was too be added, and thats when the problems started occuring. so we took it back and they replaced a solenoid the problem went away for a while and it came back just recently. If you guys could give me any insight as to whats going on in my transmission or maybe a solution i would be greatful.
Oh, one last thing. My car is a 1997 Camry LE V6 Auto
Thanks
