the best way to find out your problem...
You need yourself and another person to help you out..
Jack your car up with a good jack supporter...
1) if you have a hydrolic jack around the house... get a piece of short wood (flat), put short flat wood on top of the jack...and jack under the oil pan... WHEN YOU START TO JACK THE CAR UP, MAKE SURE THE CAR IS IN PARK AND ENGINE IS OFF.
Make sure you have a short flat wood on top part of the jack to protect the oil pan.. jack it up until you have good clearance for you to get under the car...
for extra safety, get something block front tire both back tires before you start raising your car up.
if you have a jack that come with the car, put that hand jack on the side where your manual show the proper way to jack up your car...
this is only for extra safety when you're getting under your car...
now, have some stand outside the car and crack the car...use one foot to push the gas and you're under to listen the noise...MAKE SURE WHEN YOU'RE READY TO LISTEN THE NOISE...THE CAR IS IN PARK AND IT'S RUNNING..
tell the person don't sit on the car....2 jacks are safe, but I would be more caution not to add more person weight to the car...
