You should be running at least 4ga wire in and out of the amp. Never cheap out on the ground. You can short out the amp and start a fire if it's not at least the same thickness as the positive. How big of a fuse are you running? That much wattage, I would be using at least a 60amp fuse, maybe 80. But that's also going to depend on the quality of the amp. I was using a 40amp on my 240watt old school Orion and it blew that several times, so I upped it to 50amps. Also check the wiring on the speaker, make sure it's not crossing. If one of the subs is bad, it'll cause the fuse to blow also. What gauge speaker wire are you using, what ohm are they, and how do you have them hooked up (series or parallel).
Totally stock 00' 4cyl in Sage. Looking for set of nice stock 15" alloys for cheap, got any?
