Power Steering Fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-05-2008, 07:20 PM   #1 (permalink)
Gameroom cash: $125050
View redtigerrocks's Photo Gallery
3rd Generation Power Steering Fluid
Does anyone know what kind of power steering fluid i need for a 94 Camry V6 XLE? On the cap it says Dexron Type ATF but when i went to the store their is only plain old power steering fluid with no type atf or dexron. Do i just buy the automatic transmission fluid with dexron??
redtigerrocks is offline   Reply With Quote
Old 08-05-2008, 07:42 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
ATF means Auto Transmission Fluid. Thats all you need for it, and you'll be all set!
5 Lug Corolla WHAT?
Old 08-05-2008, 08:08 PM   #3 (permalink)
so i just use automatic transmission fluid with dexron? is their a specific dexron i use like dexron II or dexron III?
Old 08-05-2008, 08:19 PM   #4 (permalink)
Do not buy from
View Zviator's Photo Gallery
check ur mannual for the specific Dexron, Dexron III come out later and expand changing interval of car that comes factory with it. Newer is better but unless u flush the tranny all the way, u shouldn't be mixing different type of fluid.
Zviator is offline   Reply With Quote
Old 08-05-2008, 09:49 PM   #5 (permalink)
Kisuke in rain
Mazeraski's Avatar
View Mazeraski's Photo Gallery
It should be recommending Dexron II or III in your manual, however, this has been replaced and it's now up to Dexron VI if I remember correctly. Usually if an ATF concerns Dexron it will say something along the lines of "recommeneded for use in vehicles specifying Dexron III..."
1992 Toyota Camry LE 5SFE 4 cyl. 2.2L
A.K.A. "Ron Burgundy"
198,000 mi. (as of February 9th, 2010) and counting
Mazeraski is offline   Reply With Quote
