very confused... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-05-2008, 11:02 PM   #1 (permalink)
View 97vulcan's Photo Gallery
very confused...
I had to slam on my brakes today, and the back ones locked up. I don't know what happened with the front ones. I have all disc brakes, and didn't think I had ABS. Until I remove my windshield washer resovior and see this thing located in my pictures. When I turn on my key, I have no ABS. Could it be the previous owner removed the bulb due to some ABS error?? IDK.
Thanks,
Adam
Ok..Its a silver box....i don't know how to post pictures on here....soooooo yeah..can someone help me there??
Mine:
1992 Camry LE 5sfe 128,000 miles
1998 Ford Contour SVT 148,000 miles(SOLD)
Wifes:
1994 Camry LE 5sfe 224,000 miles
97vulcan is offline   Reply With Quote
Old 08-05-2008, 11:17 PM   #2 (permalink)
Here is what I am talking about.
Adam
Mine:
Wifes:
Old 08-06-2008, 12:32 AM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
Yeah, it could be the bulb has been removed or it's burnt out. I don't know of any way to check it without removing the instrument cluster and checking the bulb. Maybe someone else does and they'll chime in.
Another way to find out if it's working would be to pull the error codes. Do a search on "ABS codes" (without the quote marks) and you'll probably find a thread telling how to do that. It was posted quite recently.
HTH,
BR
BMR is offline   Reply With Quote
Old 08-06-2008, 12:33 AM   #4 (permalink)
Do not buy from
View Zviator's Photo Gallery
Talking about the silver box in your pic, it doesn't look like what i used to see on camry ...
Zviator is offline   Reply With Quote
Old 08-06-2008, 09:40 AM   #5 (permalink)
So...what does that mean?? I don't have ABS?? This was under my windshield washer bottle.
thanks,
adam
Mine:
Wifes:
Old 08-06-2008, 10:36 AM   #6 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Yes, that is ABS. http://cgi.ebay.com/ebaymotors/92-93...spagenameZWDVW for a pic to confirm. You have it.
5 Lug Corolla WHAT?
Old 08-06-2008, 12:10 PM   #7 (permalink)
if there is no dash light that lights up is there some other way I can test to see if it works, besides stepping hard on the brakes. I did this and the rears locked up. Is the ABS only on the front two brakes??
thanks,
Adam
Mine:
Wifes:
Old 08-06-2008, 12:42 PM   #8 (permalink)
shajbot's Avatar
View shajbot's Photo Gallery
Can I put ABS in a non original abs equippped car?
shajbot is offline   Reply With Quote
Old 08-06-2008, 12:51 PM   #9 (permalink)
thanks,
Adam
When you turn the key, and all the dash lights come on, you should see the "ABS" light on as well. And it;s a 4 wheel ABS system. So either your ABS is not correctly working, or you need to bleed the brakes which may help.
5 Lug Corolla WHAT?
Old 08-06-2008, 12:53 PM   #10 (permalink)
The womaneater!!!!!!!!!!!
samarai912's Avatar
View samarai912's Photo Gallery
It would be a lot of work to be honest. I don't even wanna think about the work involved . won't stopp ya from flying off a cliff
GF:"samarai I want to marry you." Me:"Uhhhh..I made a mistake.I only love my car"
Camry gen4 1mz turbocharged @ ? bar(updated)
.http://www.cardomain.com/ride/3029563
samarai912 is offline   Reply With Quote
Old 08-06-2008, 12:57 PM   #11 (permalink)
shajbot's Avatar
darn....i was hoping ...could you just lie to me samarai!!
Old 08-06-2008, 01:32 PM   #12 (permalink)
no abs light, and no abs in rear. i am not going to worry about it. my luck, the previous owner had a problem with it, and took out the abs bulb.
adam
Mine:
Wifes:
Old 08-06-2008, 02:02 PM   #13 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
ABS/Wheel Speed sensors could be shot .... you definitely have ABS because you have the unit that you pictured, and you have 4-wheel disc on a 4cyl model
theyre not cheap to replace, but if you asked your local stealership they could diagnose the problem and give you a quote
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 08-06-2008, 11:34 PM   #14 (permalink)
Do not buy from
That's how i decided to stop ricing my car, i can put down an aftermarket sunroof, i can swap in leather interior, but rebuild the brake system is out of question
Old 08-06-2008, 11:51 PM   #15 (permalink)
thanks for all the input. should i replace the abs bulb and see what happens??? i can see the abs sensors in the front, but can't find the ones for the rear.
also what is the bulb for the ABS and what is the bulb for the ETC??
thanks,
adam
Mine:
Wifes:
