A couple turbo questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2008, 12:55 PM   #1 (permalink)
shajbot's Avatar
View shajbot's Photo Gallery
1. How exactly should the oil supply/return system to the turbo bearing be set up? (oil return line to oil pan but where to hook up the oil pressure unit??)
2. What actually involved in "tuning"? How hard it is to wire up a Greddy Blue Emanage to the electric.
3. Any alternative to oil catch can? And front valve cover blow-by tube?
Thanks
shajbot is offline   Reply With Quote
Old 08-06-2008, 01:17 PM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
not hard to wire up the Emanage .... tuning would basically involve setting a decent-sized list of parameters to ensure that the car is running optimally based on outputs such as air-fuel ratios and whatnot - should be done on a good, calibrated dyno by a shop that knows what they are doing
the catch can is really something you shouldnt skip - you dont have to get a huge or ugly one, but you should definitely get one because those 1MZ's are setup like that from the factory, whereas my 5S doesnt have a line from the valve cover to the intake
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 08-06-2008, 01:33 PM   #3 (permalink)
shajbot's Avatar
I don't think there is any dyno shop around my town so I can do it (tune it) by myself??? I used to program and write web script before, should I be sufficient? And wtf with all the different in
SAFC
FMU
boost controller
wideband sensors
etc....
do I need all that, I'm looking at a reliable 4-8psi setup on .60 trim compressor.
And how about the oil thing? Is turbo oil bearing supposed to be fed off from the oil filter on the block is?
Old 08-06-2008, 02:00 PM   #4 (permalink)
Venom_5's Avatar
the S-AFC is a piggyback that basically sends signals to the ECU to override the stock inputs ... if you were gonna get a Greddy Emanage, you dont need a piggyback like the S-AFC
FMU = fuel management unit ... basically a secondary fuel regulator, you will probably just need an FPR (fuel pressure regulator) and upgraded injectors & 255lph fuel pump, of course depending on power goals and turbo selection
Boost Controller (manual or electronic) just allows you to set the boost (psi) level by hand, rather than letting it run on the given wastegate spring
Wideband Sensors are just like any other O2 Sensor in your car, but have a higher resolution output so the Wideband A/F Gauge can tell you what the ratio of air-to-fuel is by reading from the exhaust (usually in the downpipe)
read the 5S-FTE sticky threads ... yes, its a different engine thats a bit more needy but it will give you a good sense of what you need, since you will need the same basic electronics
Old 08-06-2008, 04:09 PM   #5 (permalink)
shajbot's Avatar
Thanks Venom, that's very insightful.
Can I have question #1 answered too, I've searched and found none.
Old 08-06-2008, 04:57 PM   #6 (permalink)
Venom_5's Avatar
im not sure how thats done for the 1MZ-FE, thats why i havent responded ... i know exactly what to do for the 5S-FE, as you can tap into the block on the front face, use a T and send the line to the turbo
not familiar with the 1MZ block, maybe Eye8Pussies or someone else could give some insight
Old 08-06-2008, 05:05 PM   #7 (permalink)
shajbot's Avatar
Yes, please, some how I don't like the sound of tapping into the block.
Old 08-06-2008, 05:14 PM   #8 (permalink)
Venom_5's Avatar
well the block is already tapped, and thats how the majority of people do it ... or tap the oil pan
Old 08-06-2008, 05:25 PM   #9 (permalink)
shajbot's Avatar
Well tapping oil pan is for return line, where do I need to tap to to get the pressure oil to send to turbo bearing from? I was thinking the oil filter relocation kit but I need a confirmation.
Old 08-06-2008, 05:32 PM   #10 (permalink)
Venom_5's Avatar
yea my bad, i wasnt paying attention
try this: Got Boost?: Another 1MZ-FTE Project ('95 Camry XLE V6) (No 56K) - Updated 7/1/07
Old 08-06-2008, 07:28 PM   #11 (permalink)
shajbot's Avatar
Bump, I need to know how the oil supply system to be set up? And is there a definite guide for wiring up emanage....it can't be THAT simple.
Old 08-06-2008, 08:13 PM   #12 (permalink)
Venom_5's Avatar
the emanage comes with instructions, if i recall
Old 08-08-2008, 11:03 PM   #13 (permalink)
shajbot's Avatar
Bump
Old 08-08-2008, 11:49 PM   #14 (permalink)
Sleepin zZzzzz
360glitch's Avatar
View 360glitch's Photo Gallery
You' have to put a "T" in at the oil pressure switch. Unlug it, unscrew it, put in the T, screw it back on, attach the oil line to the turbo.
'01 Avalon XLS - Project Log
'92 Eagle Talon TSi AWD - Project Log
360glitch is offline   Reply With Quote
Old 08-08-2008, 11:53 PM   #15 (permalink)
PICKLE GANGSTER
Rdizzle's Avatar
iTrader Score: 6 reviews
View Rdizzle's Photo Gallery
^ exactly. Just sends the oil down another tube from the sending unit. Takes about 10 min with a pretty easy to find part. I got a pre-tapped pan if you're interested...
Originally Posted by DarkMastyr View Post
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
[U]
http://www.cardomain.com/ride/398065...ry-le-coupe-2d
Rdizzle is offline   Reply With Quote
