Toyota camry 97 , bushings - need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2008, 05:44 PM   #1 (permalink)
View PianiMasteri's Photo Gallery
Hi to everyone
this picture is rear right side toyota camry 1997 , V6 3.0 LE
problem is bushings, but dont know parts name to search online and order that bushings
so if anyone knows whats a name for that parts number 1 and 2 and also number 3 please post it
sorry for my english and thanks in advance
PianiMasteri is offline   Reply With Quote
Old 08-06-2008, 06:36 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
#1 and #2, Rear Control Arm Bushings: http://cgi.ebay.com/ebaymotors/Energ...spagenameZWDVW
#3 is just the Sway Bar Bushings
5 Lug Corolla WHAT?
Old 08-06-2008, 08:46 PM   #3 (permalink)
View JustinC25's Photo Gallery
I had to replace #2 in my '95 6 Months ago, and was unable to locate just a replacement bushing, as it ball socket design and can't be pressed in (Atleast on the Gen 3) I ended up replacing the entire
control arm/toe adjuster assy. I tryed to get a used one from a salvage yard, but they sold me one from a Gen 4 and it was too short. I do still have it thought if you are intrested.
JustinC25 is offline   Reply With Quote
Old 08-07-2008, 01:38 AM   #4 (permalink)
JvR
JvR's Avatar
View JvR's Photo Gallery
Why are you replacing 1 and 2? (sounds, no good driving,worn tyres...???)
JvR is offline   Reply With Quote
Old 08-07-2008, 02:05 AM   #5 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
They get worn. Many vehicles don't use poly bushings which are much better.
I'm going through a similar issue myself and will fairly soon down the road need to replace bushings. A lot is just due to age and use. They wear.
The rear control arms if they have movement front to back [that's the bar underneath your 1 and 2] then the bushings will need to be replaced. Now the ones you label 1 and 2, two of mine have been replaced at some point, and the other two haven't. One is starting to wear. The adjustable bar seems it's usually totally replaced rather than replacing the bushings, but they're not too cheap to do unfortunately.
cykaaro is offline   Reply With Quote
