Oil filter assembly question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2008, 01:57 AM   #1 (permalink)
all my heros are evil
cykaaro's Avatar
View cykaaro's Photo Gallery
Well, once again, my oil filter assembly is leaking again so it looks like the seal will have to be replaced.
The question is, is there a specific way this needs to be done and anything to watch out for? I'm not entirely sure how they fit on, where the seal goes etc as I'm still learning bout the engine [92 V6] and I know its hidden underneath the exhaust manifold.
Any help would be greatly appreciated.
cykaaro is offline   Reply With Quote
Old 08-07-2008, 12:24 PM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
the seal as in the rubber ring from the filter?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 08-07-2008, 01:08 PM   #3 (permalink)
View JustinC25's Photo Gallery
This is a pic of a 5S-FE, but I believe the 3VZ-FE has a simillar setup.
I have a repair manual at home, I'll try to post info tonight when I get home.
JustinC25 is offline   Reply With Quote
Old 08-07-2008, 02:36 PM   #4 (permalink)
Darkside Cut Me!!!
There is similar seal (O-ring) between oil cooler and engine block pictured above. and if you have not had a chance to, tighten the oil filter threaded stud with an open ended wrench. If the oring has never been changed, it is a good time to do that.
On my gen4 4cyl and V6 there is no oil cooler. filter seals to block.
2004 RX330 Sport
2003 Cam I4 XLE
Old 08-07-2008, 03:26 PM   #5 (permalink)
Gameroom cash: $303255
^ plus 1. If you have been getting leaks after using multiple oil filters, then it's most likely not the filters that are leaking. There is a big o-ring that seals the assembly to the engine block. That seal sometimes leaks. Cheap and easy fix. Try tightenting the assembly first as Hajoca suggested. If that doesn't stop the leak, then replace the o-ring.
Mike
Mike Gerber is online now   Reply With Quote
Old 08-07-2008, 03:46 PM   #6 (permalink)
View 97vulcan's Photo Gallery
do all gen 3's come with the oil coolers??
if not, how can you tell if yours has one.
thanks,
adam
Mine:
1992 Camry LE 5sfe 128,000 miles
1998 Ford Contour SVT 148,000 miles(SOLD)
Wifes:
1994 Camry LE 5sfe 224,000 miles
97vulcan is offline   Reply With Quote
Old 08-07-2008, 05:49 PM   #7 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
The o-ring is less than $10 and I had to get it at the lexus dealer because they evidently put more 3vz-fe in them than toyota? Anywho, I bought it, have yet to put it on, but here is my thread about it (with pictures)
3vz-fe oil filter adapter
and another thread that has the part number in there...
3vz-fe questions
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 08-07-2008, 10:41 PM   #8 (permalink)
cykaaro's Avatar
Mike
I definitely know it's the assembly that's leaking. I've picked up the o-ring already. When I changed the PCV valve it stopped, but it's started seaping again. Will see if can get easily give it a tightening before I hit the road tomorrow afternoon. With a bit of luck it'll work, but will need to be replaced eventually as I think it's probably the original one.
