Breaks problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2008, 03:47 PM   #1 (permalink)
View jakep99's Photo Gallery
Breaks problem?
yesterday a car infront breaked hard suddenly and so did i and heard a crack noise... then something was hitting the left front tire and i was hearing cruck cruck noise.. i got down and saw a pieace that was stuck (guess something broke off) so i couldn't take it off that time, but i guess it fell of while driving.. now when i break, the car slides to the right a little but that's if i break hard.
what could it be??
jakep99 is offline   Reply With Quote
Old 08-07-2008, 05:51 PM   #2 (permalink)
View toyomoho's Photo Gallery
Did something hit your car or break off your car?
Remove the tire and take a look at the brakes. If you don't know what you are looking for compare with the other side.
Old 08-07-2008, 08:44 PM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
check your brakes! on other forums every so often i hear of people either losing or shearing a bolt that connects the caliper to the mounting bracket. a broken, loose or missing missing bolt an cause a serious accident.
Old 08-08-2008, 01:34 AM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
From what you've said, something is seriously wrong. In addition to what the folks have suggested, it could be that one of your brake pads has failed, with the friction material separating from the steel backing plate. I had that happen to my Camry a long while ago.
Don't mess around, get it checked out quickly!
BMR is offline   Reply With Quote
Old 08-08-2008, 05:46 AM   #5 (permalink)
Radio, this is Unit 91...
eurohazard's Avatar
View eurohazard's Photo Gallery
Sounds like you lost a brake pad on the left side. And that is a bad thing. The reason your car pulls to the right is because the left side is doing nothing, all the stopping power is on the right side.
This happened to me once, when the pads get too worn, they can actually fall out.........get it fixed NOW. You can probably nurse it to a shop as long as you don't exceed 35 mph, definitely do not travel at freeway speeds.
1993 Camry LE 5SFE AT, 2006 Nissan Armada LE 4x4, 1971 Cadillac Coupe DeVille "pimp juice"
Toys: 2007 Coachmen 19FLB, 2007 Regal 1900 V6
I'm the biggest boss thatchu seen thus far! Baby, that's muh wi'zzard!
eurohazard is offline   Reply With Quote
Old 08-08-2008, 10:08 AM   #6 (permalink)
View longlocks's Photo Gallery
Oh my goodness. My breaks are squeaking and I am concerned about that. I wonder how much will it cost to fix them.
longlocks is offline   Reply With Quote
Old 08-08-2008, 10:52 PM   #7 (permalink)
eurohazard's Avatar
Brakes that just start to squeal, generally aren't too much to worry about. Usually it's just the wear tab doing it's job, letting the owner know the brakes are almost in need of replacement. By the time the brake pads fall out, some serious neglect has taken place.
