Bixenon h4 on a gen 4 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2008, 04:34 PM   #1 (permalink)
View evoicon06's Photo Gallery
4th Generation Bixenon h4 on a gen 4
I have a problem..one of my bixenon bulbs is out...i also discovered that one of the fuses was out so i replaced it then when i tried it again it didn't work and the fuse was blown...its definitely not the bulb because i have switched the bulbs with the same result........My bixenon kit included a harness and with a fuse that connects to the battery and 2 grounds which i have checked.....this kit has worked for for more than 2 months then all of the sudden one bulb went out....What are the symptoms of a dead ballast?...can i change the fuse to a 30mA because they have 15mA in right now....any help would be greatly appreciated....thank you
evoicon06 is offline   Reply With Quote
Old 08-09-2008, 04:46 PM   #2 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Putting in a bigger fuse is not going to solve your problem. You've got a short if your fuse keeps blowing like that. You need to check your wiring. Get a cheap digital multimeter and start checking. Probably something got knocked loose in one of these cheapo kits.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
