350z 17" rims - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2008, 04:26 PM   #1 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
350z 17" rims
I came across a set of chrome 7 spoke nissan 350z rims which have the 5x114.3 pattern like the camry. These rims are $150 with tires. I cant pass these up unless anyone knows of any fitment issues???? I guess I would need a set of hubrings for sure I am just unsure of other clearances. I don't suppose anyone has tried this.
frenum49 is offline   Reply With Quote
Old 08-10-2008, 05:14 PM   #2 (permalink)
O-Dark-30
frenum49's Avatar
hmm
NVM I bought them anyway.............
Old 08-10-2008, 05:15 PM   #3 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
here are the wheels specs:
Front
Offset: +30mm
Weight: 23.26lbs
Tire: 225/50/17
Rear
Offset: +33mm
Weight: 24.14lbs
Tire: 235/50/17
these should fit fine but they may stick out just a bit. also, you might have to use aftermarket/tuner lugs. toyota uses shank/seated lugs. nissan uses acorn type lugs.
TheKevin is offline   Reply With Quote
Old 08-10-2008, 05:24 PM   #4 (permalink)
O-Dark-30
frenum49's Avatar
hmm
Thanks for the info. I just couldn't pass these up for the money especially wrapped in Potenza rubber with 85% tread life left.
Old 08-10-2008, 05:42 PM   #5 (permalink)
TheKevin's Avatar
yea that a good deal. I was able to buy a perfect set for $100 but the tires were bald as hell. I sold those for $400 to buy a set of 18" 350Z wheels for my SC400.
take pics of it on the camry. im curious to see what they look like.
Old 08-10-2008, 05:54 PM   #6 (permalink)
O-Dark-30
frenum49's Avatar
hmm
Will do but I am not going to put these on the car until it is lowered properly.
Old 08-10-2008, 05:56 PM   #7 (permalink)
TheKevin's Avatar
true but throw em on there just to see how much of a drop you'll need. im dropped on tenzo springs and the Z wheels wont fit with that drop.
Old 08-10-2008, 06:05 PM   #8 (permalink)
The laziest around
LazyAccent's Avatar
View LazyAccent's Photo Gallery
they shouldnt be a problem if u pull and roll ur fenders. i have 17x8 bbs's and im on tenzo r springs too. i had to roll my fenders for the proper fit
Can you do the dansing and raise the roof?
LazyAccent is offline   Reply With Quote
Old 08-10-2008, 06:12 PM   #9 (permalink)
O-Dark-30
frenum49's Avatar
hmm
Yeah I was thinking of that as well which is why I was hoping to find a gen 3 guy that had tried this. I guess I have a good reason to buy height adjustable coil-overs now if needed.
Old 08-12-2008, 07:48 PM   #10 (permalink)
O-Dark-30
frenum49's Avatar
hmm
Well I went to pick up the chrome 350z 17" rims/tires today and upon inspection noticed that one of the rims on the inside bead had been split from a curb or pothole. Needless to say I was a bit disappointed until he offered me a diff set of 350z rims on even better Potenza rubber. The thing is that these are 18" rims on 225/45/18 fronts and 245/45/18 rears and they are not chrome 7 spokes but whitish silver 6 spokes but are in nearly perfect condition. I am not big on chrome anyway so I grabbed them up for the same cost. Put the rims on my gen3 at the shop and figured I am gonna need a 2" drop and rolled and pulled fenders at least in the rear. I pulled it outside for a few quik pics posted below.
Old 08-12-2008, 07:54 PM   #11 (permalink)
O-Dark-30
frenum49's Avatar
LOL my tiny rotors look hilarious under there!!!!!
Old 08-12-2008, 11:59 PM   #12 (permalink)
TheKevin's Avatar
looks pretty good. the camry must be riding really high right now.
*1 thing you should be cautious about is that these wheels may cause your wheels bearings to wear out very quickly.
Old 08-13-2008, 12:39 AM   #13 (permalink)
xet
View xet's Photo Gallery
dang that looks surprisingly good, congrats on the buy
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 08-13-2008, 01:07 AM   #14 (permalink)
Starr of Chaos
lordstarwind's Avatar
View lordstarwind's Photo Gallery
side note, would look better if you grind off the nissan emblem :P and powdercoat them gun metal
but sick none the less,
did you have to do anything to make them fit or was it just bolt up ? (eg hub centric converter ring id assume was needed, but were the studs long enough stock?)
-LSW
lordstarwind is offline   Reply With Quote
Old 08-13-2008, 01:18 AM   #15 (permalink)
View Albuynp Ryeno's Photo Gallery
Odds are you can just pry the nissan logo off.
Good job not getting chrome rims. I think chrome is tacky and it would look especially bad on a white car.
1995 Camry V6 LE - Sold
1998 Camry LE
1992 SC300 5SPD
1992 SC400
Albuynp Ryeno is offline   Reply With Quote
