Wheel Bearing Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2008, 04:28 PM   #1 (permalink)
View aleem86's Photo Gallery
I have a 99 Camry ce both rear wheel bearings needs to be changed. My question is Can the ABS wheel bearings still work in a Non-ABS car?
aleem86 is offline   Reply With Quote
Old 08-11-2008, 06:34 PM   #2 (permalink)
EverReady's Avatar
View EverReady's Photo Gallery
They should ABS is just a braking system.
EverReady is offline   Reply With Quote
Old 08-11-2008, 07:44 PM   #3 (permalink)
bro I don't understand what you are saying. I know ABS is a breaking system on the wheel bearing and the hub there is a gear for the a
ABS I want to know if it will still fit.
Old 08-11-2008, 07:50 PM   #4 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
Typically the only difference is the added ring for the ABS. The ABS model will probably fit a non ABS car but why not just buy what you actually need?
Zembonez is offline   Reply With Quote
Old 08-11-2008, 08:15 PM   #5 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Clearly I've never tried, but i imagine that it would fit. The only difference that I can think which exists in the ABS model would be the rotor on the hub and the hole drilled in the steering knuckle for the sensor. I imagine the dimensions between the two different models would be the same.
Alternatively, buy the appropriate part.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 08-11-2008, 10:19 PM   #6 (permalink)
I have already bought the bearings they cost 207. they also sell the bearings and the hub already together but they for cars with abs. with the bearings that I have now I will have to remove the bearings from the old one and press it on to the new bearings. the abs one is 146 for both and it comes with new hubs and studs.
Old 08-12-2008, 12:25 AM   #7 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
According to the "96greencamrylev6" in the thread linked below (see post #7), a wheel bearing cartridge with the ABS tone ring wouldn't fit in his '96 w/o ABS.
Rear wheel bearing R & R - How to and why
BMR is offline   Reply With Quote
Old 08-14-2008, 10:30 PM   #8 (permalink)
UPDATE: I just installed both bearings yesterday. I bought the abs one. I knocked out the abs gear very easy to come off. The bearing assembly mounted right up with no problems. Thanks
Old 08-14-2008, 10:35 PM   #9 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Good deal! Now we know.
