anyone here selling coolant reservoir? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2008, 07:24 PM   #1 (permalink)
View dleccord's Photo Gallery
the dealer is charging me about $120 for a new one.
i need a working one for 94 camry 2.2. lemme know.
thanks!
dleccord is offline   Reply With Quote
Old 08-11-2008, 07:59 PM   #2 (permalink)
4th Gen Camry Owner
View kpszar's Photo Gallery
Wow what a rip off, find one at a junk yard or make your own. I seen a soda bottle with a hose on a DSM, the bumper covered it anyway.
kpszar is offline   Reply With Quote
Old 08-11-2008, 08:18 PM   #3 (permalink)
sandfleee's Avatar
View sandfleee's Photo Gallery
check this site out...
http://www.alltoyotatrucksuvparts.com/
I was looking for another set of door panels, and they were responsive. Just send an email.
I ended up finding the panels on Ebay, but kept the link incase I needed other OE parts.
Hope this helps.
sandfleee is offline   Reply With Quote
Old 08-11-2008, 08:19 PM   #4 (permalink)
sandfleee's Avatar
Hope this helps.
OOPS...didnt see it was a camry. Sorry. have you checked ebay?
Old 08-11-2008, 09:19 PM   #5 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
http://search.ebay.com/search/search...ant&category0=
5 Lug Corolla WHAT?
Old 08-12-2008, 01:09 AM   #6 (permalink)
I appreciate yalls help. Thanks a lot.
Thanks!
Old 08-12-2008, 11:16 AM   #7 (permalink)
Heat's Avatar
View Heat's Photo Gallery
My reservoir had become brittle and had broke apart at the upper corners closest to the side of the car, just age I guess. I asked www.toyotapartsales.com about the coolant reservoir, they wanted $70 or $80 (still a lot cheaper than the dealer).
I ended up just buying a bottle of epoxy glue (for plastic) at my local hardware store for $3 or $4 and patched up my old reservoir. If you can patch up your old one, go that route.
By the way, it sounds like your dealer is charging over MSRP, just keep that in mind when you are buying parts.
Heat is offline   Reply With Quote
Old 08-12-2008, 11:47 AM   #8 (permalink)
Gameroom cash: $105400
View dz63's Photo Gallery
The coolant reservoir on my '96 Camry also became brittle at the exact same location - the two outside corners. It almost looked like the sun had deteriorated the plastic in this location - but that doesn't make much sense because the reservoir is located under the hood. I patched mine up with fiberglass drywall tape embedded in 2 coats of two part epoxy.
You can also buy on Amazon.com for $11 + $12 shipping
http://www.amazon.com/RADIATOR-EXPAN...8559465&sr=8-1
2002 Camry 2.4L Auto - 70K miles
2008 Corolla 1.8L Auto - 48K miles
dz63 is offline   Reply With Quote
Old 08-12-2008, 04:06 PM   #9 (permalink)
View Kingdom934's Photo Gallery
Seemsl ike this is a common issue...or wear and tear.
My friend's 96 LE V6 is also breaking apart where it attachs to the fender - the two outside corners. I tried going to the junkers to find a Gen3 camry with a half decent one...no luck. All had broken or near to break reservoirs.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 08-13-2008, 12:54 AM   #10 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
Yeah, sounds like a common problem. My Camry's is deeply crazed all over on top. Has been for quite a while. I expect it's going to shatter one of these times when I go to refill it, so I take the cap off VERY carefully.
BMR is offline   Reply With Quote
Old 08-13-2008, 01:21 AM   #11 (permalink)
View Albuynp Ryeno's Photo Gallery
Mine broke in the exact same place as well. It's funny my car doesnt have the ABS unit and i usually had a leak of fluid there. Eventually i realized the coolant reservoir was broken. BTW when you close the hood; if you bend over, you can see that sun can get to the corner of the reservior. I just used m jb weld and patched up the hole.
1995 Camry V6 LE - Sold
1998 Camry LE
1992 SC300 5SPD
1992 SC400
Albuynp Ryeno is offline   Reply With Quote
Old 08-13-2008, 09:15 PM   #12 (permalink)
Albuynp - If the sun can hit the two upper corners of the reservoir, then that would explain the deterioration - Toyota probably didn't consider specifying a UV stabilized plastic to mold the reservoir. As a preventive measure, it would be a good idea to spray some opaque spray paint on the corners to prevent the sun light from hitting the plastic.
One of the things that I find very interesting on this forum is exactly how many other Camry owners have the exact same problems that I have with my Camry, and I am impressed with how willing everyone is to share their solutions. TN rocks!
Old 08-13-2008, 09:34 PM   #13 (permalink)
rty
Gameroom cash: $298766
View rty's Photo Gallery
You could also pick one up at a junkyard.
rty is offline   Reply With Quote
Old 08-14-2008, 06:47 AM   #14 (permalink)
Hmm...Bad design flaw on the Gen3 I guess for that part. I wonder if Toyota was brought to news about this?
Most times it'll have that same crack. Only way you'd really find one at the junker is if the car had been in the garage most of the time. Then again, I doubt you'll find a Camry that had been in the garage all the time in the junk yard.
Hmm...Somebody might want to do an investigation. Say someone curious who goes to the junkers next time could go check a bunch of Gen3 there and see how much have crack or weaken (crack markings) on their coolant res? That would be a worth while survey since I doubt you could go around in a market place and ask moms and dads to pop their Gen3 Camry hood so you can go check their coolant res
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
Old 08-14-2008, 10:31 AM   #15 (permalink)
Alomost all in the junkyard are cracked, just get new from ebay.
5 Lug Corolla WHAT?
