Gen4('98 Camry V6)Spark Plugs Walkthrough? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2008, 12:09 AM   #1 (permalink)
View ilovemyapplesduh's Photo Gallery
Looking threw the search couldn't find anything. Also I'm not the brightest thing in terms of mechanics but I don't see where any of them are not like my V4 '97 Corolla where there right there and done. If there's not one here link me a site and I'll make one for us.
ilovemyapplesduh is offline   Reply With Quote
Old 08-12-2008, 04:55 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
just trace the plug wires. they run to coil packs so the plugs are under thoes. the front bank is easy to do but the rear bank requiers the removal of the intake manifold.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 08-13-2008, 09:56 PM   #3 (permalink)
View JustinC25's Photo Gallery
Originally Posted by bigbird View Post
just trace the plug wires. they run to coil packs so the plugs are under thoes. the front bank is easy to do but the rear bank requires the removal of the intake manifold.
Removal of the intake is not necessary.
It is tight but can be done without removing the manifold. We did them all the time this way at the dealer I used to work at. Camry is easy, Sienna is more difficult.
Anyway, start by removing the pcv valve and hose from the rear valve cover.
Next disconnect the the plug wires from the front 3 coils. Remove the 3 10 mm bolts on the front 3 coils. and pull out all 3 of the rear plug wires out of the way. (This can be accomplished by "hugging" the intake) The middle wire on the rear bank can be a little tricky to get out as it will hit the intake plenum if you pull straight out.
The trick is to pull straight to loosen it from the plug, then try to tilt it tward the driver's side and it will just clear the plenum with a little finesse.
from here you want a DEEP spark plug socket (Available from most tool guys, I got mine from snap-on, here is the link to see it http://buy1.snapon.com/catalog/item....re&dir=catalog)
A 1" extension, and a stubby 3/8" ratchet.
Remove the plugs, this is a little challanging due to the limited space but not impossible.
(My first time with a sienna took me 30 minutes)
Drop in the new plugs, tighten hand tight, and go 1/4-1/2 a turn more.
Reassemble, and DON'T forget the PCV Valve and hose.
Justin
JustinC25 is offline   Reply With Quote
Old 08-13-2008, 10:44 PM   #4 (permalink)
View 1996camry's Photo Gallery
Justin,
What brand Automatic Transmission Toyota Dealer use or you would recommend that work best for Toyota Camry?
I did flush my Automatic Transmission at 129k miles, and I did not removed the filter to clean. Now, at 135k. I want to spend time on this weekend to flush out again to minimize the dirty old transmission still inside.
What brand does Toyota Dealer use or you know good brand ATF for
1996 Toyota Camry 4 Cylinder 5SFE engine?
I am planning to get Right strut replace..Either I go OEM Toyota parts, but they want 170 bucks... I heard other brands that is close to OEM Toyota part front right strut..
Justin, do you know what brand of strut Toyota used? Or you recommend go with OEM Toyota part? Also, I want to know do I need to buy or replace any extra since I buy the right front strut. Or I can use the old parts that come with the Front Right strut? I heard it's better to replace something inside while you're there or you'll heard squeeze noise on the road... HELP ME OUT>>> I want soft drive not rough drive..so if any strut I want to buy...Soft drive has to be....
I appreciate any suggestion.... What brand to go? If I go aftermarket strut part, do I have to buy everything... I am not sure... I would like to keep close to OEM parts as possible.
1996camry is offline   Reply With Quote
Old 08-13-2008, 10:46 PM   #5 (permalink)
Justin,
What brand does Toyota Dealer use or you know best brand ATF for
Also, I am planning to get Right FRONT strut replace..Either I go OEM Toyota parts, but they (dealer) wants per 170 bucks... I heard other brands that is close to OEM Toyota part front right strut..
Justin, do you know what brand of strut Toyota used? Or you recommend go with OEM Toyota part? Also, I want to know do I need to buy or replace any extra since I am there... Or I can use the old parts that come with the Front Right strut? I heard it's better to replace something inside while you're there or you'll heard squeeze noise on the road... PLEASE HELP ME!! I want soft drive not rough drive..so if any strut I want to buy...Soft drive has to be....
Old 08-14-2008, 12:13 AM   #6 (permalink)
Awesome guys sounds like it wouldn't be super hard and got the Haines manual coming in so I'll do a DIY for us.
Old 08-15-2008, 08:06 PM   #7 (permalink)
Awesome! Just make sure that you have a VERY DEEP socket, like in the link in my last post.
It really sucks without one.
Old 08-15-2008, 08:07 PM   #8 (permalink)
Originally Posted by 1996camry View Post
Justin,
PM Sent
Old 08-15-2008, 10:49 PM   #9 (permalink)
I understand I need the very deep socket anywhere I can get one say Sub $10 not $60 plus?
Old 08-16-2008, 08:01 AM   #10 (permalink)
Ebay has one
http://cgi.ebay.com/Extended-Reach-5...QQcmdZViewItem
and Harbor Freight has one for 5 bucks.
http://www.harborfreight.com/cpi/cta...emnumber=91705
Old 08-16-2008, 02:25 PM   #11 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
I don't understand why an extra deep socket is required. Why wouldn't a normal one work with a short extension?
BMR is offline   Reply With Quote
Old 08-16-2008, 04:09 PM   #12 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
cuz a regular sized socket won't fit over the sparkplug...
HaHa
Old 08-16-2008, 04:18 PM   #13 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Yes, a normal socket won't fit, but a normal spark plug socket will. These guys are talking about a plug socket thats about 6 or 8 inches deep. I don't see why that's required.
Old 08-16-2008, 04:57 PM   #14 (permalink)
illunatic54's Avatar
View illunatic54's Photo Gallery
Justin,
you know when you replace struts, you should replace them in pairs
and TRUST is a word you seldom here from us
illunatic54 is offline   Reply With Quote
Old 08-16-2008, 08:38 PM   #15 (permalink)
TN Pussy Man
ah...
and no...that would not be required...and if they actually got a socket that long, it won't fit under the plenum and into the sparkplug tubes
HaHa
