URGENT!! STRONG smell of gas from engine bay area!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2008, 09:00 PM   #1 (permalink)
View hassanbigboss's Photo Gallery
My 1998 CAMRY V6 is giving me some trouble. I have a very strong smell of gasoline (raw smell) coming from the left side of the engine bay (when looking at the engine standing on the front) It started all of a sudden this evening when I started the car a went for a 3 mile round trip. Since it is dark outside I cannot visually inspect it. Does anyone know what the problem could be? I have to go to college tomorrow and I need to get this car fixed ASAP..TIA
hassanbigboss is offline   Reply With Quote
Old 08-12-2008, 09:26 PM   #2 (permalink)
The womaneater!!!!!!!!!!!
samarai912's Avatar
View samarai912's Photo Gallery
could be a leaking o-ring on the injector, its gotta be somewhere on that fuel rail if its on the left side of the engine. anyway take of the v-bank cover off before you drive and carry a fire extinguisher in the car. just in case. then pray that its not a big leak that will ignite while driving on the highway.
GF:"samarai I want to marry you." Me:"Uhhhh..I made a mistake.I only love my car"
Camry gen4 1mz turbocharged @ ? bar(updated)
.http://www.cardomain.com/ride/3029563
samarai912 is offline   Reply With Quote
Old 08-12-2008, 09:29 PM   #3 (permalink)
thanks for the response.......I wouldn't dare drive the car anywhere but to the mechanic. It is so strong that even after 20 minutes or maybe 30....if I go by the car....I can catch the whiff of the gas vapors.....Would it be expensive to repair if it was the O-ring around the injectors that went bad? You see I don't have much money at the moment
Old 08-12-2008, 10:20 PM   #4 (permalink)
samarai912's Avatar
well you have to take the plenum off to get to the injectors. so I don't know how long it would take someone else I can do it in under an hour but I've done it alot.hopefully its your imagination . also can be an intake gasket leak or even a plenum gasket leak. which are double stamped steel. How many miles are on the car?
Old 08-13-2008, 12:41 AM   #5 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $348853
View BMR's Photo Gallery
I don't know if a '98 is the same, but my '92's fuel filter is on the driver's side of the engine bay. That could be leaking under pressure.
BMR is offline   Reply With Quote
Old 08-13-2008, 10:07 AM   #6 (permalink)
Cars got a 190xxx miles........I can smell the gas inside the car as well, I am assuming it is the fuel filter clogged up since it is underneath the rear passenger seats. Anyhow, I am seeing a mechanic today, lets see what happens
Old 08-14-2008, 10:37 AM   #7 (permalink)
samarai912's Avatar
the fuel pumps back there. filter is under the hood on the drivers side. good luck with the mechanic hope he's a good friend.
