Where is the dimmer switch relay?
Hi, my highbeam is not working (only when I pull the indicator switch towards me. The headlights cut out altogheter when I put them on highbeam.
I tried cleaning up the indicator switch contact points (removed steering wheel, etc) and that did not work.
I tested all of the fuses under the hood with a multimeter and they all work.
I replaced the headlamp relay and that did not work.
I tested the two fuses behind the kickpanel, they work. There is a relay amongst those 2 fuses, I'm sure its not the dimmer switch as the part number of the item does not match the dimmer part number on the internet (the part number is 09087-04002 or 056700-6780)
I took the panel off underneath the steering wheel and I found some relays, are one of these the dimmer relay? It is not under the bonnet because the only relay I foulnd was the headlamp one and the efi relay.
So before I pull apart any more of the car, where is this dimmer relay located? I'm thinking of taking the glove box out, surely it cant be there?
