a stuck pcv valve can cause oil to be forced into the intake manifold, also causing similar fault. Fought that on an old Lexus es250 and saved my shop the cost of pulling the heads. Didn't really matter in the end; that motor's oil pump ate itself two months later. Try seafoaming the intake and see if the problem goes away the next couple days. Also, you're sure it's oil? bluish smoke?
to do the valve seals with the head on, you need a steady supply of compressed air to keep the valves from falling out. Also need to remove cams and valve shims (and keep them organized) and have a bolt-on valve spring compressor to reinstall the valve springs after replacing seals (removing valve springs is easy).
there's a reason most shops outsource head stuff to machine shops.
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
