IS300 Rims fitment question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2008, 12:20 AM   #1 (permalink)
werkit217's Avatar
View werkit217's Photo Gallery
4th Generation IS300 Rims fitment question
I knoe there has already been threads about fitting 17" IS300 rims on a 4th gen, but all ive been able to find are fitment guides for 3rd gens.
What size spacers would i need (if any) to make them fit my 98 Cam? I am aware that the recommended tire size is a 215/45R18, but would i be able to fit them on a set of 225/40R17 tires or would there be rubbing issues?
I build cars the way I build them, anybody who thinks any different, well... they're just wrong
werkit217 is offline   Reply With Quote
Old 08-14-2008, 01:04 AM   #2 (permalink)
View Albuynp Ryeno's Photo Gallery
I would assume the gen 3 and gen 4 would use the same spacers. Maybe someone else can verify this.
225 tires MIGHT fit. It all depends on the tire. Its like shoes, 2 different tires can be rated the same size, but might be different sizes. I know my 215 have very few space left to spare for a wider tire. That said i got a free set of 225/45ZR17 tires, so they will be my next set of tires. Hopefully they will fit.
Also I wouldnt go below a 45 tire. 40 is very low, too low IMO. The ride will be less smooth and you have a higher chance of denting the rim over a pothole or dip in the road.
1995 Camry V6 LE - Sold
1998 Camry LE
1992 SC300 5SPD
1992 SC400
Albuynp Ryeno is offline   Reply With Quote
Old 08-14-2008, 01:26 AM   #3 (permalink)
Do not buy from
View Zviator's Photo Gallery
If u havn't bought the tire already, i suggest bring those rim to the tire shop and let them install, if it need spacers, I'm sure those people have plenty of it ...
Zviator is offline   Reply With Quote
Old 08-14-2008, 09:19 AM   #4 (permalink)
werkit217's Avatar
I was just thinkin that they may fit, I recently ran a 225/40R18 n had couple millimeters to spares with those, but any other thoughts?
Old 08-14-2008, 09:58 AM   #5 (permalink)
Starr of Chaos
lordstarwind's Avatar
View lordstarwind's Photo Gallery
most shops atleast around here wont install spacers b/c its a liability... so you might have to find a shop that will do it for you...
lordstarwind is offline   Reply With Quote
Old 08-14-2008, 01:18 PM   #6 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
run the correct tire size that is the closest to OEM (try the Miata Tire Calc or TireRack if you dont know what size that is) ... the fitment issue is more with caliper clearance if i recall
it was fixed with 5mm spacers, which arent much at all - so it shouldnt be too much of a hassle even on a gen 4
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 08-14-2008, 01:46 PM   #7 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
If you just took the IS300 rims off of an IS300 and swapped em onto your 98, there would be no spacers or anything needed. You can add spacers and what not, but there are no rubbing issues.
I was running 17x7.5 +40mm offset rims with 225 width tires, and i also had no rubbing issues.
But i forgot the offset of the is300 rims.
Just a suggestion, stick with the OEM tire size.
nodrogkam is offline   Reply With Quote
