Originally Posted by angel_rolla
hello, i have a gen 3.5 camry and have a problem. everytime i use my brake i can hear a knocking sound coming from the rear. it's like knocking on hollow metal?.. it's annoying and really embarrassing. anyone have these problem before? help me out.. thanks you..
I had the same problem with my '95.
A knocking sound from the rear whenever you step on the brake.
Took me forever to figure out what it was. It turned out that my r/r lower control arm bushing was worn out and my tire was walking back and forth, but it didn't cause any odd tire wear, cause the tire was free to wander. When I checked it the tire deflected about 1/4" in either direction. I replaced the r/r lower control arm, and it has not made a noise since.
This is the part.
You can check this by jacking up the rear end, and wiggling the tire from side to side.
There should be ZERO play.
Justin
