Need help installing my aftermarket headunit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2008, 10:30 PM   #1 (permalink)
View BUNNYz's Photo Gallery
3rd Generation Need help installing my aftermarket headunit
Hello all
I have a 93 V6 LE with radio and 6 disc cd changer in the trunk and factory amp. 6 speakers.
I got my HU for cheap (amazon.com), it didn't came with any wiring harness to bypass the amp. I took my factory radio off and I saw there is only 1 connector in the back. I look at the factory amp there are 2 connectors, it looks similar to the 87+ radio wiring harness.
My question is: Do I use the 87+ radio wiring harness that is connecting to the amp and runs longer wires to the dash to hook my aftermarket HU?
Or
use the one connector located at the dash to hook up the aftermarket HU then bypass the factory amp
Thank You
BUNNYz is offline   Reply With Quote
Old 08-15-2008, 11:31 AM   #2 (permalink)
View JustinC25's Photo Gallery
Originally Posted by BUNNYz View Post
Hello all
Or
Thank You
I had the same setup in my '93 SE. Just use the 87+ style connectors that go into the amp and it will be fine.
Justin
JustinC25 is offline   Reply With Quote
Old 08-15-2008, 11:36 AM   #3 (permalink)
View boost3dsupra's Photo Gallery
if you look further in, there will be two more harnesses that are the ones you are supposed to use. I had the factory amp also. Just follow the single harness that was connected to the oem radio and you should see them.
96 Camry Collectors Edition: Daily Driver
08 BMW M3: Weekend Car
boost3dsupra is offline   Reply With Quote
Old 08-15-2008, 04:18 PM   #4 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Exactly. Same on my XLE. They are down and to the right, shoved down into the corner. Use a flashlight.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 08-15-2008, 04:25 PM   #5 (permalink)
View Albuynp Ryeno's Photo Gallery
Ya their is a second set of connectors to the right. But you can use either the 1 set or the 2 set connectors. if your headunit is good i would use the 2 connectors. That will bypass the stock amp. But if your headunit isnt as strong as the stock amp, then your system will be downgraded by using the 2 connector harness.
1995 Camry V6 LE - Sold
1998 Camry LE
1992 SC300 5SPD
1992 SC400
Albuynp Ryeno is offline   Reply With Quote
Old 08-16-2008, 12:25 AM   #6 (permalink)
thank you for all the answers.
