Gen 3 w/ annoying electrical problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-15-2008, 02:24 AM   #1 (permalink)
View jayjay86's Photo Gallery
3rd Generation Gen 3 w/ annoying electrical problems
The 10 amp fuse that controls the instrument cluster, power windows, sunroof, and a/c controls keeps blowing out. When it blows out I can't even tell how fast I'm going and how much gas I have left. Anyone else have similar problems?
jayjay86 is offline   Reply With Quote
Old 08-15-2008, 02:56 AM   #2 (permalink)
I work on euros.
View 96CamrySport's Photo Gallery
Toyota wiring seems to hit a wall when it reaches a decade old. random stuff stops working. Does it blow on any particular function, or just randomly while you're doing nothing? Blown fuse points to component going bad or short in wiring.
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
96CamrySport is offline   Reply With Quote
Old 08-15-2008, 12:24 PM   #3 (permalink)
Whenever I lower the windows, the fuse seems to blow soon after. It blew out when I hit a bump on my driveway and soon after I turned on the fan. I went to a Toyota mechanic, and all they could find was a blown 10 amp fuse.
Old 08-15-2008, 03:55 PM   #4 (permalink)
93 Camry LE V6
Barcs's Avatar
View Barcs's Photo Gallery
You could try maybe jacking it up to 15 or 20 amps, and see if it still blows. If it does you're going to have to check your wires, or have a mechanic do it.
Barcs
Barcs is offline   Reply With Quote
Old 08-15-2008, 07:02 PM   #5 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I had a similar problem. It turned out to be my air conditioner magnetic clutch. Checck out the thread it may relate:
Wierd electrical problem.
I would caution you against increasing a fuse's amperage. It could set up a dangerous condition if you aren't lucky.
Kep
Old 08-15-2008, 07:26 PM   #6 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
Fuses are made to blow when too much amperage is drawn through a circuit. Have you checked to see if its only a specific window that blows the fuse when you roll them down? Also, like the last post, it could have something to do with your ac clutch or fan motor as well. When you said that you hit a bump then turned on the fan, was the ac on at the same time? I also wouldn't suggest installing a higher amp fuse, because you're then letting more than normal amperage flow through those wires, which isn't safe at all.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 08-16-2008, 12:10 PM   #7 (permalink)
When I hit the bump, the fan wasn't on. I turned on all the accessories and used all the window controls but couldn't blow a fuse. I drove it most of yesterday but nothing would act up. Could I use a circuit breaker in place of the fuse?
Old 08-16-2008, 03:20 PM   #8 (permalink)
Kep
Kep's Avatar
You say the fuse keeps on blowing. When does it blow?
Kep
Old 08-16-2008, 07:17 PM   #9 (permalink)
It blows at random times. Once it blew after I shifted into reverse, but it mainly blows after a few minutes after starting up the car.
Old 08-18-2008, 05:25 PM   #10 (permalink)
Kep
Kep's Avatar
Crazy_Butcher just had a thread going on this:
power windows and power locks
and this is what he found from a previous “repair”:
http://i170.photobucket.com/albums/u...y/100_1569.jpg
Make a list of each system on the fuse. Disable one at a time (you may need to get creative here). When you do disable the faulty system the fuse won’t blow and you will know where to look harder. It is usually a pain to do but I can't think of any other way to do this with an intermitant problem.
Kep
